ex 95 rear disc brakes problem
i got the old pads out , and installed the new ones
but my problem is the capiler piece dont go in
and i cant get the brake piece to go over the brakes
TSPeed Factory
Re: ex 95 rear disc brakes problem (GReddy SI)
are you talking about you can't push the piston back in? if so you have to turn and push it at the same time.
Re: ex 95 rear disc brakes problem (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">are you talking about you can't push the piston back in? if so you have to turn and push it at the same time.</TD></TR></TABLE>
Just like AZNTAGGER said. if you look at the break piston you will see a " + " shape ingraved into the piston .....use a stick that will fit into one of the slots on the "+" and push gently and turn/ and dont damage the rubber linning " boot" on the piston ...oh yeah also dont forget to take the cap of the break fluid reservoir and put a rag to catch any overflow when you push both pistons in
Jerzey Rex
Suspension & Brakes
02-04-2007 01:11 PM
wickedxbo1
12-30-2001 07:51 PM
