Help!! SPEEDOMETER PROBLEM!!
Old Feb 22, 2006 | 07:39 PM
rleonekc's Avatar
Default Help!! SPEEDOMETER PROBLEM!!
1990 Honda Accord EX, Manual Transmission, 4 door.
My speedometer is broken. It rarley works sometimes.
I was wondering what the most expensive problem to fix a speedo would be and how much it would cost???
If anyone helps, Thank you!!!
-Rob
Old Feb 22, 2006 | 08:17 PM
P_Adams's Avatar
Default Re: Help!! SPEEDOMETER PROBLEM!! (rleonekc)
Is this an automatic, or a standard? You've two threads going for the same complaint
"Service engine soon" lamp on?
If so, you could have a bad Vss
It looks like this (manual Trans)
http://www.carpartswholesale.c....html
If not, suspect the cluster itself (which is the more expensive)
P
Old Feb 22, 2006 | 08:22 PM
rleonekc's Avatar
Default Re: Help!! SPEEDOMETER PROBLEM!! (P_Adams)
Service Engine soon lamp only comes on when im on the highway...
Old Feb 22, 2006 | 08:26 PM
P_Adams's Avatar
If you were to pull the DTC code, It would probably point to the VSS as well.
P
russelbit
Oct 22, 2009 12:39 AM
rleonekc
Mar 1, 2006 10:09 AM
MAD-racer
Mar 28, 2005 12:28 AM
dmrush
Jan 14, 2004 01:32 PM
