Awww crap... still rattling
I took off the cat heat shields. Still rattled. I tried to take off the exhaut manifold shield, and the dang bolts broke! Both of them! I couldn't get around to the rear mani shield. What size are those bolts? Box wrench kept slipping, and I couldn't see...
Anyway, it almost seems like the buzzing/rattling is actually worse now! It starts at about 2800 and continues up to about 4500, whereas with the shields on, it started around 3200 and stopped around 3800.
What a friggin pain!!!
Anybody have some ideas on how to stop the noise?
[Modified by chairmankaga, 9:56 PM 3/28/2002]
get a new header
I'm having the same problem, I found that my rattling was coming from where the A and B pipe meet, the bolts that hold it together (there are suppossed to be 3) were messed up. The last guy to work on my car apparently did not put one back in correctly, it fell out and caused a rattling that got worse and worse... my new header will be here tomorrow though. Good luck.
mine does the same thing, except from idle all throughout the powerband. Mine sounds like its coming from the cat. converter, though. could it be the exhaust manifold??
that's what i figured...i really wouldn't know what to look for, and i was planning on getting h/e/cat this summer, so i hope that will fix it.
thanks mang
thanks mang
go to a local shop, run the car when is up in the hoist, mostly is the heat shield or the header bracket, or could be something inside the cat is fu*ked, go to a shop and the guy should find out in no time
Had the same problem. Took off all the heat sheilds under the car, and the heatsheild thats in front of the header. Later found out its the heatsheild behind the header fuggin POS
The problem with most all `94-95 GSRs... ACTUALLY was a TSB... sadly us owners are a little TOO late for it.
The `94-95 GSRs use dual-piped a-pipes. The inner piping actually breaks loose, this breaking loose allowed it to vibrate against the outer piping. Interesting eh?
Take it to a muffler shop, they can "blow" using a torch... a hole into each pipe and weld the two pipes together... then close the hole. VERY simple process. Mine required three holes to be blown. Right before it entered the cat, and at the beginning of each pipe heading up.
Very simple fix... THIS will solve your prob. OR getting a header will!
End of post, question answered! Good day!
ViruSi
Dec 31, 2004 10:43 AM
94B18B1Teg
Mar 15, 2004 11:05 AM
