02 Sensor Questions?
I have a CEL so i took it to honda and had them hook it up and they said that it is my 02 that is causeing the CEL. BUT it goes off at times so i was just thinking that maybe it is clogged up and it could be cleaned. They also said that it was my primary sensor which i figured if anything it would be my secondary sensor since i have the DC sport RH. Any ideas. I really dont have the couple hundred dollars to be buying new 02 Sensors.
Secondly is it bad on the car to be running with a bad 02 sensor?
dont run your car on a bad primary o2...that will screw with all your cars adjustments in fuel.....
heres a link you want
http://www.kingmotorsports.com...e=RSX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCNBPDC5 »</TD></TR><TR><TD CLASS="quote">dont run your car on a bad primary o2...that will screw with all your cars adjustments in fuel.....
http://www.kingmotorsports.com...e=RSX</TD></TR></TABLE>
are you sure that one is the right one?
thats what kingmotorsports suggests...it shoudl work considering that it was under the rsx section of their site....just call them and make sure before you buy it
Modified by NCNBPDC5 at 12:10 PM 2/21/2006
Try this place. It's where I bought mine.
Honda wants $150 for one! Bullcrap!!
http://www.autopartswarehouse.com/honda~rep.html
This is by far one of the best deal on a o2 sensor, even includes the plug.
http://rywire.com/store/produc...a07af
Cleaning an o2 sensor, Im not sure this would do anything... but hey, what bad can happen if it is already screwed up right. A few sprays of carb-cleaner and a clean rag that should be ok.
Although sensors dont seem to fade or break while being repariable. Kinda like a lightbulb, if it goes IT GOES!
If it was your primary o2 sensor (controls A/F) your car would definaetly run worse than normal (although it may be slight). You secondary o2 is in charge of your car so you might wanna think about an o2 sim.
Rich
Rich
vg7z
12
May 20, 2005 05:09 AM
BlueShadow
Jan 29, 2005 08:42 AM
gulftiresinc
Sep 29, 2004 01:49 PM
