!*!Relay Help!*!
Old Feb 16, 2006 | 04:13 PM
Rukusmasta2's Avatar
Default !*!Relay Help!*!
OK so my main relay is just buzzing, and yes i searched but out of the 9 that come up they all say to check your thermostat ground and i guess that fixed everyones problem cuz no one said nothing else in those threads,,,but anyways i have my thermostat ground and it is still buzzing, i even tried directly grounding it cut the black wire and grounded it, still buzzed. i went out to my 92 DA took off that main relay and it still buzzing, my fuel pump is not priming also..i need HELP ASAP...
Old Feb 16, 2006 | 04:39 PM
CoolRedXylophone's Avatar
Default Re: !*!Relay Help!*! (Rukusmasta2)
im kind of in the same situation as you. replaced main relay, still no fuel pump, ive never heard about doing anyting to the thermostat ground wires to fix it check out my post https://honda-tech.com/zerothread?id=1530227
Old Feb 16, 2006 | 07:01 PM
Default Re: !*!Relay Help!*! (CoolRedXylophone)
bump
Old Feb 17, 2006 | 02:44 AM
B16aSir2's Avatar
Check your two grounds underneath your dash on the driver side. If you are 100 percent positive the ground at the thermostat housing is secure.
Old Feb 17, 2006 | 03:14 AM
Default Re: !*!Relay Help!*! (B16aSir2)
is one of these grounds solid black and the other one with a white stripe??
also, where is the thermostat ground
Old Feb 17, 2006 | 04:56 AM
thermostat ground should be right around your thermostat 2 wires...unless u got a wire tuck ull probably have to extend it
Old Feb 17, 2006 | 04:57 AM
out of class on break in computer lab BUMP need to know so when i get home i can start chuh-mon guyz
Old Feb 17, 2006 | 05:46 AM
leaving school to go home and sit there pissed cuz i dont know BUMP
Old Feb 17, 2006 | 03:24 PM
BUMP
Old Feb 18, 2006 | 03:27 AM
B16aSir2's Avatar
I am pretty sure it is your grounds dude.
Old Feb 18, 2006 | 08:34 AM
which grounds ,dont just repeat things
Old Feb 19, 2006 | 09:03 AM
BUMP
Old Feb 22, 2006 | 06:57 AM
bump...still pissed not working...does the VTM need to be hooke dup on the VAFC becuase this only started once i hooked up the VAFC and im wondering if that is not supposed to be hooked up on these EF's (i got 89 DX HB)
Old Feb 23, 2006 | 03:10 PM
ttt c'mon someone please i been stuck for like 3 weeks damn
Old Feb 25, 2006 | 11:49 AM
c'mon seriously someone its been weeks and i cant get it started im so pissed....i had it running a few weeks ago, i hooked up a O2 sensor and the VAFC and it just started clickin someone please help i need this thing running
Old Feb 25, 2006 | 01:01 PM
ktp1798's Avatar
Make sure the ground wires aren't ate up with corrosion. Sometimes it's hard to see so look close. The buzzing sounds like a low battery. The car does crank, just not start, right?
Old Feb 25, 2006 | 02:18 PM
Default Re: (ktp1798)
no it cranks im not gettin fuel the relay isnt lettin the fuel pump prime
Old Feb 25, 2006 | 02:40 PM
payneth's Avatar
Default Re: (Rukusmasta2)
maybe replace the relay? I dunno i have this same problem and i am going to change out my main relay with one of the extras i have sitting around. I will let you know. But it might be your fuel pump? Cause mine does this maybe once a week... i will keep you posted
oh and are you throwing any codes at all?
Modified by payneth at 3:52 PM 2/25/2006
Old Feb 25, 2006 | 03:33 PM
Default Re: (payneth)
well i did replace relay with a DA one i got here same thing and i ran a wire direct from battery to fuel pump and it turned on?? what are the chances that both relays are bad, lol and i soldered the regular one on some of the joints that looked bad and still same thing, im so stumped
Old Feb 25, 2006 | 09:01 PM
Rywire's Avatar
What did you do to the car recently? Like what mods?
Old Feb 26, 2006 | 08:13 AM
Default Re: (droppedcrxsi)
LS/VTEC motor dpfi-mpfi, obd0-obd1, and installed a 00si cluster and VAFC the thing is i had it running like 2 weeks ago, i finished wiring up the cluster and O2 sensor and VAFC and it started doin it didnt do it before that though
Old Feb 26, 2006 | 10:09 AM
Rywire's Avatar
so just randomly it started to do this? something broke or came loose
Old Feb 26, 2006 | 06:50 PM
i solder just bout every connection ive mad in the car...its so wierd seiriously...none of those wires that have to do with the VAFC or O2 sensor could possibly affect it??
Old Feb 26, 2006 | 09:34 PM
Rywire's Avatar
Put it back to how it was I guess
dirtyundies
Mar 26, 2016 12:17 PM
raverx3m
Sep 16, 2011 11:09 PM
3M TA3
Sep 2, 2006 09:22 PM
Project91Hatch
Sep 1, 2006 01:44 AM
phatrick2332
Jul 9, 2004 01:05 PM
