Car Shaking
1994 Civic Hatch Manual--
Alright everytime i sit at stop lights or w.e ill put it in netural and it just shakes, not a weak shake either like everything in the car is shaking. Seems to be getting worse now so seeing if anyone would know why
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by McGeeTM »</TD></TR><TR><TD CLASS="quote">ok..so whys my car shaking so bad</TD></TR></TABLE>
check your mounts
hows your idle?
check your mounts
hows your idle?
dude, if you are spitting oil out the exhaust you have bad rings or valve stem seals, either way you are going to foul plugs like a mother causing incomplete combustion and a very very rough idle because the car will be running on less than all 4 cylinders. also check your plug wires one might have came loose.
