should oil pressure be lower on a low comp. engine?
Old Feb 14, 2006 | 06:20 PM
hatchinprogress's Avatar
Default should oil pressure be lower on a low comp. engine?
i just built my dohc zc .....and the compression came out lower then i planned (8:1) but it is boosted, while i installed the motor i also hooked up an auto-meter oil pressure gauge (it's mech.) when im driving the gauge reads around 75-80 psi, when the car is warming up it reads around 60 psi....but when i let the car idle it reads right under (or at) 20 psi.
why is it only 20 psi at idle???? (the reason im worried is because my integra has around 30-35 psi @ idle)
Old Feb 14, 2006 | 07:32 PM
Default Re: should oil pressure be lower on a low comp. engine? (hatchinprogress)
am i the only 1???
Old Feb 14, 2006 | 07:36 PM
RCautoworks's Avatar
Oil pressure is pretty much determined by the oil pump, and more so the bearing clearance.
Old Feb 15, 2006 | 04:12 AM
Default Re: should oil pressure be lower on a low comp. engine? (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Oil pressure is pretty much determined by the oil pump, and more so the bearing clearance.</TD></TR></TABLE>well clearance should be ok, because when i drive i hit 80 psi.....is it bad that i only get 20 psi during idle?
Old Feb 15, 2006 | 04:57 AM
crx_88_si's Avatar
no.. when my sending unit was working my crx would go that low @ full warm idle. I wouldnt worry about it.
don't forget ZC is D-series, Integra = B-series. different motors = different oil specs.
Old Feb 15, 2006 | 12:27 PM
Default Re: should oil pressure be lower on a low comp. engine? (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">no.. when my sending unit was working my crx would go that low @ full warm idle. I wouldnt worry about it.
don't forget ZC is D-series, Integra = B-series. different motors = different oil specs.</TD></TR></TABLE> yeah i know they are different motors.....i mentioned integra because it was the only car i could base my readings off of
Old Feb 15, 2006 | 02:44 PM
d16dcoe45's Avatar
that is fine. I built my motor about 5 months ago and I get (when fully warmed up) about 25-30 at idle and about 85 at high rpm. When cold I am at like 80 idle (when I first start the car). You have good oil pressure. What I have (and is a good idea) is an oil pressure gauge (a good simple one) which I assume you already have and also a big warning light (it will come on whenever the pressure drops below say 18 psi) and don't mount the sensors on the block, run a -4an braided line to the firewall where the sensors are. Also, I have a 2 qt. Canton Accusump with a manual ball valve plumbed with -10an line. If you evef get low oil pressure (say driving in a long corner) the Accusump acts as an oil resevoir and will push like 10-20 seconds of oil until the car regains oil pressure on it own--also it acts as a pre-oiler I have like 30psi before I even start the car. They are cheap (relativley for what they do) like $400 for the whole setup including the an line.
Old Feb 15, 2006 | 02:49 PM
ludesrv's Avatar
Using your setup D16dcoe45 will prolong engine life by a good ammount, and basically remove start up wear. Best setup you can run!
Old Feb 15, 2006 | 04:57 PM
Default Re: (ludesrv)
wow $400!!!! but i guess it's worth it
trulyshavedintegra
Dec 9, 2012 05:06 AM
ProjectBB6
Sep 16, 2009 02:18 PM
Ls InTeGrA RaCeR
Jan 4, 2005 08:08 PM
Harassing Herbs
Mar 16, 2004 05:09 PM
USDM 4G VTEC
Sep 3, 2003 08:26 PM
