any way to eliminate the evap system??
Old Feb 13, 2006 | 08:22 PM
j_fukin_t's Avatar
Default any way to eliminate the evap system??
like above says is there any way around this?? if so thanks in advance
Old Feb 13, 2006 | 08:32 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: any way to eliminate the evap system?? (j_fukin_t)
Sure. Take it out.
Old Feb 13, 2006 | 08:34 PM
94hatchling's Avatar
yes you can. but i dont know why you would want to? it robs no power, doesnt hurt gas mileage (actually helps) and only activates when at a steady cruising speed, so who cares if it replaces a little air/fuel? and if all the sudden you go WOT, it closes. so no loss in power.
Old Feb 13, 2006 | 08:49 PM
j_fukin_t's Avatar
no its just that i keep throwing a CEL for diff parts of it, thats the only reason why, and is there any way to keep the CEL off w/ it out??
Old Feb 13, 2006 | 08:54 PM
Default Re: (j_fukin_t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_fukin_t &raquo;</TD></TR><TR><TD CLASS="quote">no its just that i keep throwing a CEL for diff parts of it, thats the only reason why, and is there any way to keep the CEL off w/ it out??</TD></TR></TABLE>
not that i know of. with it gone, it will still throw a CEL. just replace the parts that are bad, then no CEL.
Old Feb 14, 2006 | 08:52 AM
j_fukin_t's Avatar
damn, i wish i knew what part was bad, i've already changed the canister and stuff but i guess i'll keep tending to the moneypit
Old Feb 14, 2006 | 09:18 AM
Out of every
thats weird i dont have a vacuum canister, never had the evap silenoid even with stock maifold, and im only using one line from the charcoal canister that i dont even need and i get no cel's. also, my car still butterflies with all those missing with a blox manifold. dont ask me how. all i have is 96 jdm gsr converted to obd1. so i just plugged up all the vacuum nipples i didnt need.
Old Feb 14, 2006 | 05:14 PM
j_fukin_t's Avatar
damn emmisions bullshit, i'm really starting to not like this car
invisible
Feb 21, 2008 06:11 PM
Lethal_Threat
Apr 13, 2007 04:34 PM
kobeRy_si
Honda S2000
Mar 29, 2006 12:35 PM
d16y8EL
Oct 25, 2004 01:34 PM
