D16 turbo vs b16 turbo vs ls turbo
Im so confused i dont know what i want. I havent the three options and i cant decide which one i want due tho tha fact that i dont plan to spend over 3000. So can some of yall give me some suggestions on what to do and i want it to be a reliable daily driver.
f sohc go dohc y make 195 whp when u can turbo the dohc and get 270whp with the right tunner and if u already have turbo kit for sohc all u have to do is change exhaust mainfold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecman69 »</TD></TR><TR><TD CLASS="quote">f sohc go dohc y make 195 whp when u can turbo the dohc and get 270whp with the right tunner and if u already have turbo kit for sohc all u have to do is change exhaust mainfold</TD></TR></TABLE>
Huh?
Turbo b18 can make the most power for cheap, I think. Xenocron is making 300 whp on his stock b18 block.
Huh?
its all about money....the d-series will run out of breath before the LS will and the LS will run out of breath before the b16, but to reach each motor's potential you have to fork over more and more money....so set your hp goals and lay down a budjet and then decide what to do.
not to jack thread but i am going through the same ordeal, i have about 5500 to spend, and all i have is a d series turbo kit....no motor!
same delema here im thinking of switching to a b20vtec after a customers car made consistent 11.8's on a stock block on 12psi of boost. cars been running for 3months and regularly brought to the track.
im torn between a built D or a b20/ls vtec turbo
alright. ive had a d16 turbo, ls turbo, and an lsvtec turbo.
the d16 was smooth, but only ran 6-7 psi. it was very fun.
the ls turbo was nice, ran it up to 12 psi 100% stock motor, moved well, got me low 14 second slips.
the lsvtec was about 12 psi, but i had a much better exhaust setup. was night and day over the ls, which was night and day over the d16.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by userdead626 »</TD></TR><TR><TD CLASS="quote">not to jack thread but i am going through the same ordeal, i have about 5500 to spend, and all i have is a d series turbo kit....no motor!
sell the d kit, have like 7k, and build an lsvtec turbo
unisysEK
Apr 20, 2004 12:52 AM
