is a turbo K20 engine worth the money rather than a turbo B16?
is a turbo K20 engine worth the money rather than a turbo B16 on an EK hatch?
i just want some input to see whether or not putting a turbo on a K20 is worth the money and the labor. i know that a B16 block can hold a lot of boost if it is sleeved right and i know that a turbo B16 mashes out, but i want to be a bit different and try to turbo a K20. if you have any suggestions or advice, write back.
thank you, unisysEK
thank you, unisysEK
Depends on what you are using the car for. k20a daily driver, throw it in 6th and cruise. b16a turbo will be faster and less reliable. hope that helps, i say do the k20a
JayBone12
05-16-2010 10:09 AM
