gas pedal prob...
Old Feb 11, 2006 | 06:34 AM
fiend4boost's Avatar
Default gas pedal prob...
sometimes my gas pedal gets stuck a little. i drive a boosted del sol and i got a apexi s-afc that i use also to monitor. the gas pedal sometime get stuck and instead of idling @ 850+rpm it idles at like 1400+rpm @ like 0.02% throttle. i can like use my foot to pull the gas pedal towards me and it'll settle where its suppose to.
please let me know what u think
thanks for looking
pix4clix
Old Feb 11, 2006 | 06:36 AM
ThefirstPACT's Avatar
Default Re: gas pedal prob... (fiend4boost)
I think there might be a throttle cable recall on your car. I know there is a recall on the civics...Just a thought!
Besides being your thottle cable it could/maybe be your TB!
Dutch
Old Feb 11, 2006 | 07:03 AM
i can say that the car use to have a hood scoop and water mixed with debri dirty up the engine bay. i was told to clean the throttle cable/TB area which worked for like a few days.
Old Feb 11, 2006 | 08:05 AM
jdmeg9's Avatar
Default Re: (fiend4boost)
maybe try spraying wd40 on the return spring area on the throttlebody
Old Feb 11, 2006 | 09:52 AM
^^^ thats wut i was talking about... i did that and it werked for a few days... anyone else?
Old Feb 11, 2006 | 11:12 AM
Brodie Bruce's Avatar
try cleaning out the inside of the throttle body. Somtimes crap builds up in there preventing the butterfly valve from operating like it should.
Old Feb 11, 2006 | 11:17 AM
B18C1EM1's Avatar
that use to happen to my 00 si and theres a nut on the front right bottom side of the throttle body try adjusting that and it ahould fix ur problem just a thought
Old Feb 11, 2006 | 11:24 AM
SigmaOmega's Avatar
hmm didnt say anything on the gas pedal in my Haynes manual on del sol's, i can only imagine that there is no tension on ur cable, id check the cable near the throttle body to see if you have slack in the line. But im just guessing..
Old Feb 11, 2006 | 11:26 AM
thanks for everyones responce... keep them comming cuz i will try wutever yall throw at me.
Old Feb 11, 2006 | 11:36 AM
Why dont you get a known good TB and try that...
Old Feb 11, 2006 | 11:40 AM
blkSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThefirstPACT &raquo;</TD></TR><TR><TD CLASS="quote">Why dont you get a known good TB and try that...</TD></TR></TABLE>
cuz the problem might not be his tb... i had the same problem on my 99 si, where i had to pull the gas pedal out with my foot a little bit, but it went away before i could fix it
edit: and why are all civics on recall?
VietCloud7
May 6, 2008 04:46 PM
Nick M
14
Apr 22, 2006 08:26 AM
joeg26er
Feb 19, 2003 06:15 PM
Cat
Sep 30, 2002 06:48 AM
sa21199
Jan 4, 2002 03:25 PM
