obd1 chassis, obd2 motor swap in there but going back to obd1?
Old Feb 10, 2006 | 11:44 PM
so simple's Avatar
Default obd1 chassis, obd2 motor swap in there but going back to obd1?
i have a 95 gsr w/ a 97 obd2 gsr swap in there. the motor is dead so i might purchase an obd1 longblock tomorrow. the longblock is missing the distributor and intake manifold though.
will the obd2 distributor work on the obd1 longblock since theres an obd2 harness in my car? the person im buying the longblock from said my obd2 harness should work fine on the obd1 longblock. should i run into any problems with the swap? arent like the injectors etc different also?
Old Feb 11, 2006 | 05:55 PM
jdmcars.com's Avatar
Default Re: obd1 chassis, obd2 motor swap in there but going back to obd1? (so simple)
What ECU are you running?
The dizzy will work and bolt up the the OBD1 GSR?
If you are running an OBD2 US ECU and putting the OBD1 Longblock in -you will need to put an OBD2 oil pump for the sensor that is not on the OBD1 Longblock.
If you are running OBD1 ECU or JDM ECU -you don't have to worry about the above statement.
Old Feb 11, 2006 | 07:39 PM
so simple's Avatar
running an obd1 gsr ecu
Old Feb 28, 2007 | 09:55 AM
so simple's Avatar
Default Re: (so simple)
obd1 chassis, obd1 ecu, obd2 harness, going from obd2 longblock to obd1 longblock, everything should work?
Old Mar 3, 2007 | 08:12 PM
jlfrnce's Avatar
will a dizzy from 94 ls work on a 01 gsr engine & ecu?
JdM_Eg6_SiiR
Engine Management and Tuning
Dec 6, 2010 07:12 AM
19CivicSi99
Jun 17, 2007 03:29 PM
boost fed ls
Aug 6, 2004 05:06 AM
1hotvtec
Oct 12, 2003 07:29 PM
1man
Jul 21, 2003 11:45 AM
