should i use a block guard on my turbo d16
Old Feb 5, 2006 | 08:41 AM
hondaguyexsi's Avatar
Default should i use a block guard on my turbo d16
im currently building my z6 all forges internas but stock sleeves. im planning on boosting 15 to 20 psi so im wondering if a block guard is a good idea and if all the bad facts about them are untrue. help me out!!!!
Old Feb 5, 2006 | 10:55 AM
pip9's Avatar
Default Re: should i use a block guard on my turbo d16 (hondaguyexsi)
i ran one in my car. d16 turbo. I never ran into any problems that i believe were caused by using it. I had it in two different engines. im about to put it in my next engine build. I have the race eng one tho. it doesnt seem to have as big of holes as some other brands i've seen.
Old Feb 5, 2006 | 11:11 AM
Blaze45's Avatar
Brrraaaap!
Default Re: should i use a block guard on my turbo d16 (pip9)
If you install a blockguard properly, then you shouldnt have any issues running one. If you havent seen the latest thread about the SOHC hatch that layed down 460hp on stock D series sleeves (the pink full race one), see if you can dig it up. I would just save my $ for sleeves and ditch the blockguard and get it tuned by somebody who really knows what they are doing....
good luck
Blaze
Old Feb 5, 2006 | 11:24 AM
Benjithx's Avatar
Default Re: should i use a block guard on my turbo d16 (Blaze45)
They are useless and in some cases (mine) can ruin your engine
Just tune it right and you will be fine
Old Feb 5, 2006 | 11:43 AM
Dunc's Avatar
BCICAN
Default Re: should i use a block guard on my turbo d16 (Benjithx)
Simple answer: no
Old Feb 5, 2006 | 11:53 AM
hondaguyef's Avatar
Default Re: should i use a block guard on my turbo d16 (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">Simple answer: no</TD></TR></TABLE>
x2.
Old Feb 5, 2006 | 12:06 PM
urbansi's Avatar
I was going to say search, but <U>no</U> works also, its about as educated as a remark as mine is
Old Feb 5, 2006 | 01:51 PM
Dunc's Avatar
BCICAN
Default Re: should i use a block guard on my turbo d16 (urbansi)
Old Feb 5, 2006 | 02:00 PM
Benjithx's Avatar
well put
Old Feb 6, 2006 | 12:18 PM
pip9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">
I was going to say search, but <U>no</U> works also, its about as educated as a remark as mine is </TD></TR></TABLE>
it sure is
MikeyL513
Apr 17, 2012 05:57 PM
sikandfastHatch
Feb 10, 2012 02:27 PM
Ferio_EG9
Dec 24, 2008 04:48 AM
driftam1
May 9, 2008 08:25 AM
SiRay13
Aug 26, 2006 02:22 PM
