should i use a block guard on my turbo d16
im currently building my z6 all forges internas but stock sleeves. im planning on boosting 15 to 20 psi so im wondering if a block guard is a good idea and if all the bad facts about them are untrue. help me out!!!!
Re: should i use a block guard on my turbo d16 (hondaguyexsi)
i ran one in my car. d16 turbo. I never ran into any problems that i believe were caused by using it. I had it in two different engines. im about to put it in my next engine build. I have the race eng one tho. it doesnt seem to have as big of holes as some other brands i've seen.
Re: should i use a block guard on my turbo d16 (pip9)
If you install a blockguard properly, then you shouldnt have any issues running one. If you havent seen the latest thread about the SOHC hatch that layed down 460hp on stock D series sleeves (the pink full race one), see if you can dig it up. I would just save my $ for sleeves and ditch the blockguard and get it tuned by somebody who really knows what they are doing....
good luck Blaze |
Re: should i use a block guard on my turbo d16 (Blaze45)
They are useless and in some cases (mine) can ruin your engine https://honda-tech.com/forums/images...s/emthdown.gif
Just tune it right and you will be fine |
Re: should i use a block guard on my turbo d16 (Benjithx)
Simple answer: no
Re: should i use a block guard on my turbo d16 (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc »</TD></TR><TR><TD CLASS="quote">Simple answer: no</TD></TR></TABLE>
x2. |
I was going to say search, but <U>no</U> works also, its about as educated as a remark as mine is https://honda-tech.com/forums/images/smilies/emwink.gif |
Re: should i use a block guard on my turbo d16 (urbansi)
well put https://honda-tech.com/forums/images/smilies/emthup.gif |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi »</TD></TR><TR><TD CLASS="quote">
I was going to say search, but <U>no</U> works also, its about as educated as a remark as mine is https://honda-tech.com/forums/images/smilies/emwink.gif </TD></TR></TABLE> it sure is https://honda-tech.com/forums/images...s/emthdown.gif |
