Head gasket???
Old Jan 20, 2006 | 12:06 PM
CiViC I2aCeI2
Guest
Posts: n/a
Default Head gasket???
Hi, im not sure if I have a bad head gasket or not. I don't have white smoke coming out of my exhaust. However, my coolant preservior always need to be refilled every 2 or 3 weeks. Can anyone tell me what it is??
thanks..
Old Jan 20, 2006 | 12:16 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Head gasket??? (CiViC_I2aCeI2)
I'm pretty sure the coolant tank fluctuates as the are gets warmer/cooler so I think you're fine.
If you don't have a shitload of white smoke that smells like sweet weirdness and no brown mud looking oil in there you should be good
Old Jan 20, 2006 | 12:19 PM
ek9pr's Avatar
You might have a small puncture in one of many coolant lines
the car necesarilly wont blow white smoke out of the exhaust pipe it all depends where the head gasket is burned up (if it is)
heres a test that might work, your car has to be <U></U> COLD! <U></U> or cold enough to take off the radiator cap. turn your car on and wait until it reaches the norm temperature, if you see a lot of bubbles coming up in the radiator its probably a bad gasket
hope this helps
Old Jan 20, 2006 | 12:34 PM
EM1_'s Avatar
B A N N E D
what if theres oil comin from the head?? where it connects between the head and block?
Old Jan 20, 2006 | 03:27 PM
ek9pr's Avatar
Default Re: (EM1_)
well you cant really tell if theres some oil coming off the sides of the head/block until you clean it well enough and just let it idle. because the leak can be coming from somewhere else and as you drive and wind blows it can spread all around
hope that helps
Old Jan 20, 2006 | 03:29 PM
SL_RICK83's Avatar
Default Re: (ek9pr)
does the upper radiator hose feel tighter than usual??
Old Jan 20, 2006 | 06:46 PM
CiViC I2aCeI2
Guest
Posts: n/a
Default Re: (SL_RICK83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SL_RICK83 &raquo;</TD></TR><TR><TD CLASS="quote">does the upper radiator hose feel tighter than usual??</TD></TR></TABLE>
I'm not sure....Is it suppose to be tight??
Old Jan 20, 2006 | 06:49 PM
CiViC I2aCeI2
Guest
Posts: n/a
Default Re: (CiViC_I2aCeI2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9pr &raquo;</TD></TR><TR><TD CLASS="quote"> your car has to be COLD! or cold enough to take off the radiator cap. turn your car on and wait until it reaches the norm temperature, if you see a lot of bubbles coming up in the radiator its probably a bad gasket</TD></TR></TABLE>
I can't get it to reach the normal temp, because coolant over flow (with the radiator cap off) and i didn't want it to leak all over the place.
beat ignition
Honda Civic (2001 - 2005)
Jun 7, 2019 04:24 AM
CRuby
33
Nov 20, 2014 11:07 AM
Chaveli
Dec 11, 2009 04:07 PM
Si_chRis
Oct 17, 2006 03:04 PM
gsrvtec2
Oct 16, 2005 12:14 AM
