installed thermostat but heat is not very hot
Old Jan 18, 2006 | 03:07 PM
drjay2022's Avatar
Default installed thermostat but heat is not very hot
i installed a new thermostat today and now i do have some heat. But it is as strong as it should be. anything else i could do?
Old Jan 18, 2006 | 03:09 PM
Spracer03's Avatar
is the heater valve opn the firewall opening all the way?
Old Jan 18, 2006 | 04:06 PM
CGags13's Avatar
Default Re: installed thermostat but heat is not very hot (drjay2022)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drjay2022 &raquo;</TD></TR><TR><TD CLASS="quote">i installed a new thermostat today and now i do have some heat. But it is as strong as it should be. anything else i could do?</TD></TR></TABLE>
yo man check your heater core, the fan, and the cable for the door
a new thermostat wont make your heat hotter
Old Jan 18, 2006 | 05:01 PM
EGDC2CIVIC's Avatar
Default Re: installed thermostat but heat is not very hot (CGags13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CGags13 &raquo;</TD></TR><TR><TD CLASS="quote">
a new thermostat wont make your heat hotter</TD></TR></TABLE>
it wont? not even if the old one was stuck open? of course it will.
did you bleed the air out of the system?
Old Jan 18, 2006 | 05:27 PM
drjay2022's Avatar
Default Re: installed thermostat but heat is not very hot (EGDC2CIVIC)
yes i bleed the air out, where is the cable for the door?
Old Jan 18, 2006 | 05:31 PM
95DxSi-R2
Guest
Posts: n/a
try bleeding it again, are u doing it with the engine off
Old Jan 19, 2006 | 10:36 AM
drjay2022's Avatar
Default Re: installed thermostat but heat is not very hot (95DxSi-R2)
yes i am doing it with the car off, and when you say bleed it, where should i bleed it from
thanks, jay
Old Jan 19, 2006 | 11:59 AM
riceburnerryan's Avatar
you have to burp the system
1. fill the coolant to the brim
2. start the car
3. bubbles should start forming in the coolant
4. the coolant level should drop, so add more coolant
5. It will smoke, its ok
6. just keep doing this until the coolant doesnt drop anymore
Old Jan 19, 2006 | 12:07 PM
drjay2022's Avatar
Default Re: (riceburnerryan)
ok thanks
Old Jan 20, 2006 | 11:30 AM
drjay2022's Avatar
Default Re: (drjay2022)
well i "blurped" the system and it is still not very warm. Where would the cable be for the door? thanks
invisible
44
Feb 22, 2008 01:33 PM
92eg6lsvtec
14
Feb 15, 2007 01:34 AM
130R
17
Dec 27, 2004 07:07 PM
fridexter
Nov 20, 2004 02:52 PM
