The Itr's Comrpession Is LOW...NEED Help......
Old Jan 18, 2006 | 08:14 AM
DRKSol's Avatar
Default The Itr's Comrpession Is LOW...NEED Help......
We did a compression test yesterday and the results were:
cyl 1- 110
cyl 2- 110
cyl 3- 118
cyl 4- 120
Oh Yeah...Its a Boosted R...Just needed some info on what else except for rings it could be
Old Jan 18, 2006 | 08:16 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: The Itr's Comrpession Is LOW...NEED Help...... (jh)
Did you do the test right?
Old Jan 18, 2006 | 08:32 AM
Dave_B's Avatar
Those are way low.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">Did you do the test right?</TD></TR></TABLE>
Old Jan 18, 2006 | 08:39 AM
Chubz's Avatar
Default Re: (Dave_B)
thats definitly your rings taking a **** on you. do a leakdown test to see if thehead gasket and valve seals are a part of the problem as well
Old Jan 18, 2006 | 09:40 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh &raquo;</TD></TR><TR><TD CLASS="quote">We did a compression test yesterday and the results were:
cyl 1- 110
cyl 2- 110
cyl 3- 118
cyl 4- 120
Oh Yeah...Its a Boosted R...Just needed some info on what else except for rings it could be</TD></TR></TABLE>
did you do the test with the engine warm and the throttle open?
Old Jan 18, 2006 | 10:14 AM
92TypeR's Avatar
FSAE
Default Re: The Itr's Comrpession Is LOW...NEED Help...... (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">did you do the test with the engine warm and the throttle open?</TD></TR></TABLE>
Beat me to it. I'm guessing the throttle was closed.
Engine temps need to be somewhat close to operating temps, and the throttle need to be WOT.
Since the numbers are very close to eachother, I do not suspect there is a problem, but rather your procedure in doing the compression test.
Old Jan 18, 2006 | 10:41 AM
DRKSol's Avatar
Default Re: The Itr's Comrpession Is LOW...NEED Help...... (92TypeR)
I guess i did the test right..Why would you need the trottle open?
Old Jan 18, 2006 | 10:42 AM
rodimus's Avatar
lol
Old Jan 18, 2006 | 10:44 AM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh &raquo;</TD></TR><TR><TD CLASS="quote">I guess i did the test right..Why would you need the trottle open? </TD></TR></TABLE>
That is how you perform a compression test. You keep the throttle at 100% open and perform the test when the engine is at a near operating temperature. The numbers are not right unless you perform the test under the above circumstances.
Old Jan 18, 2006 | 11:00 AM
cool guy name
http://www.c-speedracing.com/h...t.php
Old Jan 18, 2006 | 11:40 AM
DRKSol's Avatar
Default Re: The Itr's Comrpession Is LOW...NEED Help...... (walker111)
update: 150 all across....with the trottle open and distributor unplugged: (should it be?)
Old Jan 18, 2006 | 11:43 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh &raquo;</TD></TR><TR><TD CLASS="quote">update: 150 all across....with the trottle open and distributor unplugged: (should it be?)</TD></TR></TABLE>
yes the distributor and ecu fuse should be unplugged. if you dont unplug the dizzy you can fry your ignition coil. he ecu fuse stops fuel from getting injected into the cylinders.
Old Jan 18, 2006 | 11:46 AM
migs's Avatar
Couldnt you just pull the harness plug near the brake master cylinder?
Old Jan 18, 2006 | 11:48 AM
andyt's Avatar
I understand about the throttle being open, and why you wouldnt want fuel, but the ignition coil thing I don't understand. Why is the coil at risk during a compression test?
What is the correct way to say, check for spark?
Wouldn't you at that point be turning the engine over with the plug wires disconnected from the spark plugs? How is that really any different?
Someone please enlighten me...
Old Jan 18, 2006 | 11:49 AM
cool guy name
Default Re: The Itr's Comrpession Is LOW...NEED Help...... (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">Couldnt you just pull the harness plug near the brake master cylinder?</TD></TR></TABLE>
I've always thought about that but never tried it.
Old Jan 18, 2006 | 12:12 PM
Bradstard's Avatar
If you want, we can do another compression test at my place on Saturday. Those numbers seem very low...
Old Jan 18, 2006 | 12:27 PM
DRKSol's Avatar
Default Re: The Itr's Comrpession Is LOW...NEED Help...... (Bradstard)
what time?
Old Jan 18, 2006 | 12:58 PM
mx524's Avatar
Default Re: The Itr's Comrpession Is LOW...NEED Help...... (andyt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyt &raquo;</TD></TR><TR><TD CLASS="quote">I understand about the throttle being open, and why you wouldnt want fuel, but the ignition coil thing I don't understand. Why is the coil at risk during a compression test?
Someone please enlighten me...</TD></TR></TABLE>
in a nut shell because when the plugs are out of the head and the wire boot....meaning you have open plug wires....there is no where for the spark to discharge causing the coil to be damaged.
Old Jan 18, 2006 | 03:37 PM
01usjdmr's Avatar
It will most likely discharge and ignite something in the engine compartment. Especially if the fuel isn't disabled. Or if there are vapors.
Old Jan 18, 2006 | 03:55 PM
andyt's Avatar
Default Re: The Itr's Comrpession Is LOW...NEED Help...... (mx524)
Ok lets review for a second.
(I still don't understand...)
Electricity flows from the battery to the ignition coil, which acts as a transformer, generating a large burst of energy which goes into the distriibutor and is disbursed through the rotor to each plug in time. Now, if it doesnt jump the gap, where does it go? Your telling me it goes back to the rotor, back through the dizzy into the coil and shorts it out??
Old Jan 18, 2006 | 04:18 PM
totsie7944's Avatar
let someone whos done a compression testbefore help you out man. As long as they are even across the board I will have to agree and say that your just doing it wrong and everything is most likely ok.
Old Jan 19, 2006 | 01:18 AM
projectTeG's Avatar
i thknk it woul just ve easier to unplug the dizzy and pop the fuse if you ask me.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyt &raquo;</TD></TR><TR><TD CLASS="quote">Ok lets review for a second.
Electricity flows from the battery to the ignition coil, which acts as a transformer, generating a large burst of energy which goes into the distriibutor and is disbursed through the rotor to each plug in time. Now, if it doesnt jump the gap, where does it go? Your telling me it goes back to the rotor, back through the dizzy into the coil and shorts it out?? </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyt &raquo;</TD></TR><TR><TD CLASS="quote">I understand about the throttle being open, and why you wouldnt want fuel, but the ignition coil thing I don't understand. Why is the coil at risk during a compression test?
it wont be able to discharge its energy, basically like looping a wire back into a battery.
sik96teg
Feb 29, 2008 06:36 AM
Boosted Chemist
May 4, 2007 06:33 AM
-HONDA-
Dec 19, 2006 10:58 PM
joostan
Nov 29, 2005 07:01 AM
gsr~hatch
Apr 17, 2003 03:19 PM
