Just did a compression test.....
Old May 3, 2007 | 01:53 PM
Boosted Chemist's Avatar
Default Just did a compression test.....
Well after i built this motor i saw compression in the 175psi range. I recently got my car out of storage and just did a test. 140 cross the board. Every cylinder. I used this test on my truck and got 170 cross the board (beat to hell 94 22re) Isnt it wierd to have such low reading? Im on a decent tune that is conservative and all my afrs seem to be proper in boost.
Old May 3, 2007 | 01:54 PM
ProJectCvic's Avatar
Default Re: Just did a compression test..... (Boosted Chemist)
was the motor warm up b4 the test?
Old May 3, 2007 | 01:55 PM
Default Re: Just did a compression test..... (ProJectCvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic &raquo;</TD></TR><TR><TD CLASS="quote">was the motor warm up b4 the test?</TD></TR></TABLE>
Yeah just driving around, 9:1 b16a 81mm (sorry forgot to post info) and tb was open
Old May 3, 2007 | 02:27 PM
Finland's Avatar
Drive it around for a while, a few days..
It may just be bad ring seal from sitting so long, maybe even rusted sleeves/rings..
Old May 3, 2007 | 02:34 PM
Default Re: (Speed Industry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed Industry &raquo;</TD></TR><TR><TD CLASS="quote">Drive it around for a while, a few days..
It may just be bad ring seal from sitting so long, maybe even rusted sleeves/rings..</TD></TR></TABLE>
Yeah ive been driving for a week now. I hope the gauges is off by 20-30lbs.
Im happy that the number are consistent, but just a little worried. You guys know how nerve racking F/I **** is.
Old May 3, 2007 | 04:02 PM
turbosi03's Avatar
Default Re: (Boosted Chemist)
Actually, I got the same exact numbers... 140 across. fully built b16 9:1 pistons, .019" top ring, .021~.024" second ring gap.
I've always had this reading even when the motor was freshly built. It ran strong for 13k miles and sat for over a year... Did compression check recently and came up with same readings, different gauge (same type).
So we're either both ok or screwed... I say if it runs strong, and numbers are consistant then don't worry
Oh thats right it's a boosted Honda... Worry about something else
Old May 3, 2007 | 04:06 PM
CRX T-Si's Avatar
Default Re: (turbosi03)
Drop some Seafoam in that sucka to clean up the engine a bit to see if that would help.
Old May 3, 2007 | 04:30 PM
rmcdaniels's Avatar
9:1 motors have relatively low compression. 140 is probably fine. If you're worried about it, then do a leakdown test on it.
Old May 3, 2007 | 05:04 PM
Default Re: Just did a compression test..... (rmcdaniels)
Yeah it does run very strong, a little smoke in boost, but i think my turbo seals are toast. (oil in charge pipe+dripping out of chra) I think im going to do a leakdown, and if its shitty rebuild this winter, but for now if its going down...its going down hard
Old May 3, 2007 | 05:57 PM
93supercoupe's Avatar
the first motor i built, i never did a leakdown test, just for the factt hat i didnt want to rebuild if it was beat.
It ran strong, so i put my worries else where
Old May 3, 2007 | 07:08 PM
blackeg's Avatar
Default Re: Just did a compression test..... (93supercoupe)
when i got my ls motor first running after sitting in a junkyard from march- november it had like 150ish psi compression. after around a week or 2 of driving it came up a good 20-30 psi. i wouldnt worry and def give it more time
Old May 4, 2007 | 05:38 AM
Default Re: Just did a compression test..... (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">when i got my ls motor first running after sitting in a junkyard from march- november it had like 150ish psi compression. after around a week or 2 of driving it came up a good 20-30 psi. i wouldnt worry and def give it more time</TD></TR></TABLE>
Cool thanks dude
Old May 4, 2007 | 06:04 AM
Alfa Turbo's Avatar
If you are not getting much blow-by I would not worry about it. if you do see a lot of crap coming out of your breather... your rings would be suspect.
Drop a spoon full of oil in there and see what you get.
Old May 4, 2007 | 06:10 AM
Default Re: Just did a compression test..... (Alfa Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alfa Turbo &raquo;</TD></TR><TR><TD CLASS="quote">If you are not getting much blow-by I would not worry about it. if you do see a lot of crap coming out of your breather... your rings would be suspect.
Drop a spoon full of oil in there and see what you get.</TD></TR></TABLE>
After beating on it at idle i get some, not a ton but there is def a little smoke coming out of my endyn catch can.
Old May 4, 2007 | 06:27 AM
Alfa Turbo's Avatar
It would show up the most under boost.
Old May 4, 2007 | 06:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alfa Turbo &raquo;</TD></TR><TR><TD CLASS="quote">It would show up the most under boost.</TD></TR></TABLE>
Yeah some smoke under boost, but i think its to blame on the turbo seals.
berettagtz117
Mar 6, 2007 04:09 PM
Fat Chick Magnet
Sep 28, 2006 06:24 PM
DRKSol
Jan 19, 2006 01:18 AM
AzntaggeR
10
Oct 18, 2004 07:25 PM
tweekerz
Apr 30, 2004 09:43 AM
