EK Civic Overheating...
Old Jan 16, 2006 | 05:22 PM
CiViC I2aCeI2
Guest
Posts: n/a
Default EK Civic Overheating...
My 00 civic overheat when i'm idling for 2 min or longer. It reaches about 75% or more. However, my radiator fan doesn't turn on when it's overheating. Can anyone tell me why?
Thanks..
Old Jan 16, 2006 | 05:53 PM
platinum00's Avatar
Default Re: EK Civic Overheating... (CiViC_I2aCeI2)
fuse, relay, therostate, fan blew up.
does the fan turn on if you run power to it from the battery.
platinum.
Old Jan 16, 2006 | 06:01 PM
to slow's Avatar
the thermostat may be stuck, its a cheap easy fix, though its just a guess your water pump may be bad , maybe even a head gasket . if your water level is good it rules out the water pump, unless its a slow leak, but you should see if there is oil in the antifreeze or antifreeze in the oil . check your hoses and make shure they are not kinked , do a compression test . if that all checks out i'd start with the thermostat
Old Jan 16, 2006 | 08:09 PM
CiViC I2aCeI2
Guest
Posts: n/a
Default Re: EK Civic Overheating... (to slow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">does the fan turn on if you run power to it from the battery.</TD></TR></TABLE>
Yes, the fun does turn on...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by to slow &raquo;</TD></TR><TR><TD CLASS="quote">the thermostat may be stuck, its a cheap easy fix, though its just a guess your water pump may be bad , maybe even a head gasket . if your water level is good it rules out the water pump, unless its a slow leak, but you should see if there is oil in the antifreeze or antifreeze in the oil . check your hoses and make shure they are not kinked , do a compression test . if that all checks out i'd start with the thermostat</TD></TR></TABLE>
How would I know if my water pump or head gasket is bad?
Old Jan 16, 2006 | 08:59 PM
ek9pr's Avatar
if the fan does not turn when engine reaches its normal temp its the thermoswitch it'll run you about $18
Old Jan 16, 2006 | 09:00 PM
DestructoEH's Avatar
My guess is your fan switch is bad or you are low on coolant. You could rig the fan to stay on my jumping the connector that connects to the switch on the thermostat housing (fan switch). It could very well be your headgasket or water pump. To check the headgasket, do a compression test. If there's a dip in cylinder pressure, that could be it. You could also check the water pump for proper operation by removing the lower timing belt cover and looking for a small hole on the outside of the water pump (maybe more than one) leaking water. These holes are called weep holes and will release water when the water pump fails to operate as it should. Hope this helps somewhat... bump for more responses.
[edit] Forgot to add that jumping your fan to stay on will result in a cooler running motor, but may cause you to run rich because the engine isn't at a certain temp by the ecu's specs. [/edit]
Old Jan 16, 2006 | 09:07 PM
chad's Avatar
Moderator
search under my name....
i created a my car is overheating thread!!
Old Jan 16, 2006 | 09:15 PM
CiViC I2aCeI2
Guest
Posts: n/a
Thanks for all the info guys... I'll check everything you guys just told me and see what's wrong...
nonpoint986
17
Apr 17, 2012 03:21 AM
Boostn B20
48
Oct 18, 2008 08:08 PM
BlackEkB20
Jun 19, 2008 01:54 AM
ebabasa
Feb 9, 2008 11:48 PM
4505
Oct 12, 2003 05:28 PM
