intake mani.
Old Jan 9, 2006 | 10:27 PM
Turbo_y8's Avatar
Default intake mani.
I picked up a skunk2 pro series intake manifold, and i am putting a new intake mani. gasket on it for sure,
now my question(s) is/are do i have to replace the throttle body gasket, and when i swap the injectors from the y8 mani to the skunk2 mani should i get new clips?
thank you
Old Jan 9, 2006 | 10:41 PM
SoClose's Avatar
Default Re: intake mani. (tuck'd98)
im for sure u can use your stock throttle-body . . BUT !! the point is that your getting a after-market intake manifold . . which lets the engine suck in more air . . but how big (mm) is your stock throttle-body ? . . so basically you will be restricting air-flow being able to get inside . . unless a after-market throttle bodie is then equipped to it . .
Old Jan 9, 2006 | 10:46 PM
lemon_juice's Avatar
just as long as the throttle body is smaller than the intake manifold bore, things wouldnt get messy besides the fact that the tb will be the bottle neck. everytime u take off your tb you should get a new gasket for that.
i would suggest porting the tb to match the bore of the intake manifold
Old Jan 9, 2006 | 11:21 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: intake mani. (lemon_juice)
If your car is not a EX, then you have the shitty y7 IM, and anything else is a improvement. Get a new TB gasket, i got one offline when i ordered parts from hondaautomotiveparts.com it was like 3 bucks.
you do not "swap" injectors. Take all of em out and the fuel rail. you re-use your fuel rail and fuel injectors. the rail/injectors are bolted on with the bolts on those sticks, and snug into the IM with 4 rubber seals that you coat with oil before installing. I bought new ones only to find the old seals were perfect. So no parts needed really.
Old Jan 10, 2006 | 08:59 AM
Turbo_y8's Avatar
Default Re: intake mani. (Redline96LX)
thanx alot for the help, and yes my car is an ex, but i may get a b18b(Ls) throttle body.
I was hoping i didnt have get new seals for the injectors, since in spring my car will be turbo, so im just putting this one now for ***** and giggles and later upgrading to 310cc injectors
Old Jan 10, 2006 | 09:00 AM
Turbo_y8's Avatar
also the pro series is desgined for a stock throttle body, but you can always upgrade to something bigger
johan60
May 6, 2016 01:08 PM
ShinotakuX
Sep 9, 2008 09:21 AM
Integacivic
Jul 31, 2004 01:59 PM
zilverz
Jun 23, 2002 12:58 PM
