10w30 syntec oil or 10w30 regular motor oil in my b16a2 transmission
i need to know if i can use full syntec motor oil in my b16a2 transmission
it has 76k or should i use 80w90 syntetic blend or 10w30 regualr oil,.
dont know what to use
Re: (Ruben19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 »</TD></TR><TR><TD CLASS="quote">what about 10w30 castrol syntec</TD></TR></TABLE>
i've always been partial to this, though i've never tried that purple stuff
Darth ModerVader
Re: (smash fascism)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smash fascism »</TD></TR><TR><TD CLASS="quote">Go to Honda and get Honda MTF.</TD></TR></TABLE>
Either that, or get some GM or Pennzoil Synchromesh fluid.
Re: (Padawan)
wow never knew you could use reg motor oil in a tranny...
i run redline MT-90 in my celica and its been working well. i'm not sure if that would work well in a honda tranny or not. i think it is 75w90 if i remember correctly.
Re: (Ruben19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Average Al »</TD></TR><TR><TD CLASS="quote">10w30 works
honda mtf works
snycro mesh works
syncro if there are grinds present- i personally have used 10/30.
honda mtf works
snycro mesh works
Re: (smash fascism)
Re: (Draggin99Si)
i was told not to ever put anything but tranny oil, especially Honda's Manual Tranny oil. I will never put anything else in my tranny, and i have a b16 as well with a S21 tranny
Guest
Posts: n/a
Re: (t0ekn3e)
seems like you can put whatever you want in there huh? i was told to put only motor oil in by my engine builder but jeff evans put mobil 1 gear oil in my trans and said its the best so i dunno wif i should leave it in there or change to motor oil.
Re: (blucivicSl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blucivicSl »</TD></TR><TR><TD CLASS="quote">seems like you can put whatever you want in there huh?</TD></TR></TABLE>
No, you can't, but honda does specify what weight motor oil can be used in the tranny.
ApolloSpeed
38
03-13-2006 11:22 AM
