Testing for spark, something went wrong???
I have a 95 Civic Ex auto. I tried testing for spark by removing the spark plug #1, plugged in a different spark plug and crank the engine. The car started and I see spark. I then told my freind to shut engine off and after that car won't start anymore. It only cranks and don't know what happened, there is no spark either. Before the test it started with no problems at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Ex_Sedan »</TD></TR><TR><TD CLASS="quote">I don't understand what he did. </TD></TR></TABLE>
Removed one plug wire, put the plug into it and turned the car on while leaving the other three wires attached. A Civic will run fine on three cylinders for a long time, so it started and he burned something/shorted something out.
I've burned out an ignition coil before doing that. Good thing I had a spare otherwise I would have owed my friend a $80 coil.
"u burnt out the icm....
get another distributor "
One of my freind told me that was the method of testing for spark?
Does anybody know if I could use the dx distibutor on the ex and please expain what the icm is. Sorry still very new here..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">I've burned out an ignition coil before doing that. Good thing I had a spare otherwise I would have owed my friend a $80 coil.</TD></TR></TABLE>
This happened to me too. I had to replace the coil.
Former User
17
Aug 19, 2016 09:34 AM
