Prob with speakers
Ok iv got a weird prob
All right My Subs Work but nothing else The stero system has been in the car for about a year and a half with no prob and sudenly as i was geting on the highway my other 4 speakers stop working all at once and just sub are hiting
If i turn the Amp on high pass i can still hear the voices out of the subs so i dont understand whats wrong
This is whats all connected:
2 JL 10's
Allpine HU
Pioners spekers in the doors and rear deck
Kicker Amp
2 JL 10's
Allpine HU
Kicker Amp
I had the exact same problem! But it just dissapeared , I have no clue why it did that. After that , my subs would cut out and the full ranges would stay on. Then my headlights would blink with the bass , then all of a sudden . . . . nothing was wrong and my bass hit harder then ever. WTF?
You will have to be more spicific about your setup. How many amps do you have? Are your interiors running off the deck amp or external amp? Obviously what ever source is powering your interiors has the problem. Most likey a grounded out speaker wire a blown speaker or a bad amp.
Your internal amp in the HU has a protection circuit that will shut the amp down in order to protect it from blowing. One of your speakers and speaker wire are causing the amp to shut down. Best way to find out which one is to disconnect each speaker one at a time with the radio on at the back of the deck. IE cut the wires for the front right, no sound? reconnect and cut the wires for the front left. I fthe sound come back on after cutting one of the speakers you know where you problem is. Check the speaker to see if its blown or the wire connected to it have a short. If none then its possible the internal amp in the radio is bad. Mine went bad in my alpine no biggy just connected a 4 ch amp the RCA preouts should still work.
Feuerraeder
Audio / Security / Video
Dec 24, 2002 09:06 AM
Il update on how it goes
