Something is wrong with my baby! Help!
Old Jan 7, 2006 | 04:45 PM
civicEXtreme's Avatar
Default Something is wrong with my baby! Help!
Its a d16y7
It reved and hit limiter, then I popped it in neutral and kept reving
At the time of this happening I was trying to beat a yellow light. Anyone have this problem? A friend of mine said it sounds like a problem with the idle trottle control.
Modified by civicEXtreme at 8:21 AM 1/12/2006
Old Jan 7, 2006 | 04:50 PM
520_Motorsports's Avatar
Default Re: Something is wrong with my baby! Help! (civicEXtreme)
you might have a stuck throttle cable. clean out you throttle body and see if it goes away, check for binds in the cable.ect
Old Jan 7, 2006 | 04:54 PM
EJ4door's Avatar
Default Re: Something is wrong with my baby! Help! (SlowAzEg)
Well it sounds to me like the throttle cable is on to tight.. adjust it
Old Jan 7, 2006 | 06:58 PM
SicilianSpeed42's Avatar
could be more simple that a stuck throttle...heres the story... As you mentioned i was drivin and it all of a sudden hit the rev limiter so i put it in neutral and got the pedal back. Luckily i was about 1000 feet from my local napa so i pulled in and got some carb cleaner and sprayed it on. As i continued on to my girlfriends it happened again, so i figured it must need a scrubbin. I asked my gf for an old toothbrush as i refused to drive with her in the car if its acting up. Turns out my floormat was ridin up and my pedal got stuck behind it. So check for that and if not do what i mentioned with a toothbrush and carb cleaner.
Old Jan 7, 2006 | 06:59 PM
professor poon's Avatar
Default Re: Something is wrong with my baby! Help! (SicilianSpeed42)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SicilianSpeed42 &raquo;</TD></TR><TR><TD CLASS="quote">could be more simple that a stuck throttle...heres the story... As you mentioned i was drivin and it all of a sudden hit the rev limiter so i put it in neutral and got the pedal back. Luckily i was about 1000 feet from my local napa so i pulled in and got some carb cleaner and sprayed it on. As i continued on to my girlfriends it happened again, so i figured it must need a scrubbin. I asked my gf for an old toothbrush as i refused to drive with her in the car if its acting up. Turns out my floormat was ridin up and my pedal got stuck behind it. So check for that and if not do what i mentioned with a toothbrush and carb cleaner.</TD></TR></TABLE>
My floormat has stuck my pedal down too... Scared the **** outta me
Old Jan 7, 2006 | 07:12 PM
Default Re: Something is wrong with my baby! Help! (professor poon)
mine usually stops me from achieving full throttle!!! HAHA!
Old Jan 7, 2006 | 07:23 PM
JDM-EJ1's Avatar
Default Re: Something is wrong with my baby! Help! (EJ4door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ4door &raquo;</TD></TR><TR><TD CLASS="quote">Well it sounds to me like the throttle cable is on to tight.. adjust it </TD></TR></TABLE>
Exactly. It's definitely something with the throttle cable, that would be the only thing to keep it revving.
Old Jan 12, 2006 | 07:20 AM
Turns out it was my floor mat, cause I caught it doing to same thing yesterday. Some how it getting wedged under the pedal seems to give it gas.
StayKrafty
11
Nov 6, 2022 01:50 PM
jdmsir96
Jan 7, 2008 04:59 PM
shabam
Oct 9, 2007 05:10 PM
shabam
Oct 9, 2007 02:20 PM
MysteryWagon
Mar 27, 2003 09:37 PM
