First turbo Build: 2.5" or 3" downpipe
Old Jan 5, 2006 | 04:34 AM
BoostinEm1's Avatar
Default First turbo Build: 2.5" or 3" downpipe
Ok, this is my first turbo build and i really dont know what to do, as far as downpipe size and exhaust size. One friend says," hell yeah go 3, why not" and the other is like, " dont do that its stupid" so i dont know what i should do .
I was seeing if any one could give me some insight to the pros and cons of a 2.5 downpipe to full 2.5 exhaust and the same for a 3 inch ?
I have ...
B18b
Skunk2 intake manifold
B16 TB bored to Itr specs
DSM 450's
BMC race log manifold
Greddy type rs BOV
Tial sport waste gate 38mm 6psi spring
Turboxs boost controller
Jonny Race car Frontmount intercooler with 2.25 inch intercooler piping
Gsr Tranny
Exedy Stage 1 organic clutch
8lb balanced flywheel
Obd2b-to-Obd1 conversion tuned on Uberdata
WE are looking to run 6psi and 12psi on a dual stage boost controller
Garrett T3To4e COMPRESSOR SPECS:flow: 53 lbs/min 678cfm.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:.63 A/R HOUSINGSTAGE 3 WHEEL
All in a 99 si shell
All the feed back i can get would be greatly appreciated!
Old Jan 5, 2006 | 05:31 AM
BoostinEm1's Avatar
Default Re: First turbo Build: 2.5" or 3" downpipe (BoostinEm1)
Some one help Please!!
Old Jan 5, 2006 | 05:33 AM
zeroice's Avatar
from what i have read/done you wont need 3 inch for 12 psi. 2.5 should be good for 15ish depends on your power goals but almost everybody i know is running 2.5 including me.
Old Jan 5, 2006 | 06:29 AM
GDM Z28's Avatar
Default Re: First turbo Build: 2.5" or 3" downpipe (zeroice)
i used a 2.5" and made 304whp at 14 psi. a bigger dp would be better but 2.5 will be fine for a stock ls.
Old Jan 5, 2006 | 07:06 AM
Turbro's Avatar
The larger the downpipe the faster the turbo will spool. It's up to you, if you can fit 3" w/o many problems go with 3" if it's going to be one big headache to try to get 3" to fit go 2.5". Turbo's dont like exhaust, the bigger and the less the better. -Nick
Old Jan 5, 2006 | 10:05 AM
BoostinEm1's Avatar
thanx guys any one else
Old Jan 5, 2006 | 10:58 AM
Tactic$'s Avatar
<--- Turbo EM1.
Do it right the first time. (3")
Im sure you could make acceptable power with the 2.5", but you will (eventually) limit your potential HP output if you start to upgrade your booooosterz.
dnbruut's Avatar
Default Re: (BoostinEm1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbro &raquo;</TD></TR><TR><TD CLASS="quote">The larger the downpipe the faster the turbo will spool. It's up to you, if you can fit 3" w/o many problems go with 3" if it's going to be one big headache to try to get 3" to fit go 2.5". Turbo's dont like exhaust, the bigger and the less the better. -Nick
i couldn't of sayd it better!
Old Jan 5, 2006 | 11:11 AM
Mr. Vapor's Avatar
Default Re: (dnbruut)
Listen:
i too have a turbo EM1. a 2.5" DP will get you to 300whp and thats about it. if you're plans are to stay below 300 then go with it. but if you think for one second you want to go beyond that, save yourself the trouble of buying two DPs and go with the 3" right off the bat.
its as simple as that sir.
Old Jan 5, 2006 | 04:29 PM
Dialectic's Avatar
Default Re: (Mr. Vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Vapor &raquo;</TD></TR><TR><TD CLASS="quote">Listen:
its as simple as that sir. </TD></TR></TABLE>
Really? I have an EM1 with the B16 and am running 15 psi and I make 361 whp with a 2.5 in. DP. Just my experience.
Old Jan 5, 2006 | 05:39 PM
Mr. Vapor's Avatar
Default Re: (Dialectic)
what are your other specs...do you have the same turbo as he has listed?
Old Jan 5, 2006 | 11:13 PM
Dialectic's Avatar
Yep, except it's a 57 trim.
Old Jan 6, 2006 | 07:15 AM
f1 vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dnbruut &raquo;</TD></TR><TR><TD CLASS="quote">
i couldn't of sayd it better!</TD></TR></TABLE>
x2
also if u want more power then 3" is the way to go
Old Jan 6, 2006 | 08:17 AM
kameleon23's Avatar
Default Re: (f1 vtec)
I have a 50 trim, pushing 340 HP...2.5 inch downpipe/3 inch exhaust.
Old Jan 6, 2006 | 08:38 AM
EVIL Hx Coupe's Avatar
Default Re: (kameleon23)
I would go for 3" just because of the quicker spool. You can make alot of power on a 2.5" downpipe, but since you're getting one now, might as well go with the one that will support the most power.
That right there is total BS. I've seen people do over 600whp on a 2.5"dp.
https://honda-tech.com/zerothread?id=1382007
Old Jan 6, 2006 | 09:42 AM
red cx's Avatar
Default Re: (Tactic$)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tactic$ &raquo;</TD></TR><TR><TD CLASS="quote">Do it right the first time. (3")</TD></TR></TABLE>
the bigger the better.
Old Jan 6, 2006 | 12:42 PM
nerdsports's Avatar
it all depends on how much space you have...
id WANT a 3" dp off the bat, but if i couldnt fit it b/c of a/c and what not, then id just go with a 2.5 flared to 3"...
thats what my friend did on the same turbo & motor and his doesnt take that long to spool..
Old Jan 6, 2006 | 02:04 PM
Mr. Vapor's Avatar
Default Re: (EVIL Hx Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL Hx Coupe &raquo;</TD></TR><TR><TD CLASS="quote">I would go for 3" just because of the quicker spool. You can make alot of power on a 2.5" downpipe, but since you're getting one now, might as well go with the one that will support the most power.
https://honda-tech.com/zerothread?id=1382007</TD></TR></TABLE>
great, im not trying to start an e-thug fight you dude. i never said it wasnt possible, take a second to re-read my thread. im simply stating, and i think EVERYONE in this forum will agree INCLUDING yourself that, if you plan to make some GOOD WHP numbers right from the bat, and you're given the CHOICE at the beginning of a 2.5" or a 3" DP which would you choose?
most of us when we first built our motors opted for the 2.5" DP for one of several reasons: Money, convenience (say it was a friends and he gave it to you) or didnt have plans to make crazy #s right off the bat. i mean how often do we see a member saying "oh its i jsut want 280whp and thats it, its street driven" and then you see them come back a year later saying "ok, i wanna make 500whp"
ok im rambling, point is from the start of a build, which would you chose? sure you can make over 300whp, but its just not logical if you have the chance to go with a 3"
ok cool, yea im drunk lol..
Old Jan 6, 2006 | 08:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Vapor &raquo;</TD></TR><TR><TD CLASS="quote">great, im not trying to start an e-thug fight you dude. i never said it wasnt possible, take a second to re-read my thread. im simply stating, and i think EVERYONE in this forum will agree INCLUDING yourself that, if you plan to make some GOOD WHP numbers right from the bat, and you're given the CHOICE at the beginning of a 2.5" or a 3" DP which would you choose?
ok cool, yea im drunk lol..</TD></TR></TABLE>
Not trying to start an e-fight here either. I'm about to start drinking
SPITVENOM67
Jun 30, 2014 04:20 PM
Evilparadize
Oct 27, 2007 10:09 AM
urnotfast
Mar 20, 2007 06:46 PM
ekboost
Jul 26, 2004 08:51 PM
J-Brooks
Jun 25, 2003 10:51 AM
