Fuel pressure wount drop... searched
Old Jan 3, 2006 | 05:52 PM
BiG Chris's Avatar
Default !! HELP !! Fuel pressure wount drop... searched
Ok so yesterday i was driving my car and all of a sudden it acted all wierd and it went to super rich at idle and the above 2500 it would start to go lean. I got home popped the hood and seen that my fuel pressure was at 70psi i tried to adust the fpr and nothing with or without the vac line the pressure is still at 70psi. I checked for kinks in the fuel line and i didnt see anything. i changed fpr and nothing i removed the fmu and still the same. Im so stuck and i want to race this weekend any help please!!!!
My setup:
stock pump
stock injectors
fpr
jrsc
jrsc fmu
Modified by BiG Chris at 9:40 PM 1/3/2006
Old Jan 3, 2006 | 07:48 PM
gsrhatchy's Avatar
bump cause you need to go to the track this weekend come on someone has to have had a similar problem
Old Jan 3, 2006 | 09:54 PM
BiG Chris's Avatar
ok changed main relay too and it didnt help
Old Jan 4, 2006 | 08:30 AM
BiG Chris's Avatar
morning bump cuz i need help
Old Jan 4, 2006 | 11:48 AM
technine's Avatar
Default Re: !! HELP !! Fuel pressure wount drop... searched (BiG Chris)
Maybe fuel pump? I don't know, you replaced the fpr, took off the FMU... I don't know what else it could be that is making your fuel pressure go up that high. Maybe try replacing the fuel rail?
Old Jan 4, 2006 | 01:18 PM
BiG Chris's Avatar
yea im going to see if i can get a differnt fuel pump in tonight
Old Jan 11, 2006 | 12:15 PM
technine's Avatar
Default Re: (BiG Chris)
Did you find out what the problem was?
Old Jan 11, 2006 | 01:05 PM
BiG Chris's Avatar
well i blew air through my lines and it cleared right up and its running good as ever i didnt change out the pump since i fixed the problem
Old Jan 12, 2006 | 03:45 PM
technine's Avatar
lol, wow, I guess there was a blockage somewhere?
vietxdragon
Mar 23, 2007 10:03 AM
astig* DC2
Jul 13, 2005 02:04 PM
Familycarfromhell
Feb 9, 2003 07:40 PM
IVANITR
May 6, 2002 07:16 PM
JM Performance
Dec 20, 2001 03:51 PM
