check light on!!!!
hey guyz, today i took my car for a drive and i notice that my car is much much more quieter than normal, usually it would be hella loud cuz of 2.5 straight pipe, and it seem like it really weak, and it throw me a cell code 43, which is fuel supply system circuit, is that correct? and wat the heck is that mean...i tried to seach but the search thing said temp. not avail. thanks alot
Reset the ecu, drive and see if it comes on and if its the same code. 43 is Fuel supply system=problem with Ho2s circuit(o2 sensor circuit) or fuel supply. I can email you the flow chart if needed.
just remove the clock/radio fuse in the engine compartment for 10 seconds or remove the negative battery cable, a flow chart is a diagnostic list of things to check for codes
o ok, did that for awhile, then start the car drive around, it still throw me that code...kinda weird that the car run smoother and quieter, not that im complainin, i was kinda glad it run smooth and quieter but the check light is botherin me
btws, i have that chart, thanks though
hahahaha i was hopin u guyz would tell me wat might be wrong, i wont be able to get it check until next week or so cuz my mechanic went on vacation
PDXHatchback
Jan 1, 2007 12:32 PM
