How to remove shifter
Old Dec 29, 2005 | 02:59 PM
slow_redcivic's Avatar
Default How to remove shifter
I want to chop my shifter but im a noob and i was wondering if someone could write a how to so i can take it out and chop it and then reweld it. thanks guys greatly appreciate it.
Old Dec 29, 2005 | 03:07 PM
-Gambit-'s Avatar
Default Re: How to remove shifter (slow_redcivic)
take off shift ****, take out the 12 mm bolt that holds the shift link to shifter. Then take out the 2 10 mm bolts that hold the shifter in place.
Old Dec 29, 2005 | 03:08 PM
Default Re: How to remove shifter (-Gambit-)
alrighty thanks that'll do it on a 95 Ej?
Old Dec 29, 2005 | 03:10 PM
-Gambit-'s Avatar
yep its the same for all civic but the ep3
Old Dec 29, 2005 | 03:14 PM
OK i took off the shift **** and removed the 2 center peices and there is that black thing at the bottom of the shifter how do i take that out to get to those bolts?
Old Dec 29, 2005 | 03:16 PM
-Gambit-'s Avatar
you have to remove it from under the car
Old Dec 29, 2005 | 03:17 PM
wouldn't happen to have pictures by chance i could take a look at?
Old Dec 29, 2005 | 03:18 PM
-Gambit-'s Avatar
no pics sorry
Old Dec 29, 2005 | 03:19 PM
but from under the car i should be able to see it pretty easy or is it hard to find?
Old Dec 29, 2005 | 03:22 PM
-Gambit-'s Avatar
its easy, just follow the shift links back to the shifter, Take out the bolts that hold the shift link on. Then follow the shifter up and you will see the 2 bolts you take out to drop your shifter
Old Dec 29, 2005 | 03:23 PM
alrighty thanks any idea where i could find pics?
Old Dec 29, 2005 | 03:24 PM
streetracerof06's Avatar
just jack up the car and take a look at things and you will see what has to be done, shouldn't be a problem at all. Good Luck
-Gambit-'s Avatar
got me there
Old Dec 29, 2005 | 03:25 PM
DYRcivic's Avatar
http://importnut.net/shifter.htm
here you go man step by step
alrighty thanks guys i'll see if i can find pics. i would go check it out but it snowed 6" here and i just got home so its really wet under my car.
Old Dec 29, 2005 | 03:26 PM
-Gambit-'s Avatar
Default Re: How to remove shifter (DYRcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DYRcivic &raquo;</TD></TR><TR><TD CLASS="quote">http://importnut.net/shifter.htm
here you go man step by step</TD></TR></TABLE>
thank you. You just dont have to drop the shift links from the tranny for what you are doing
Old Dec 29, 2005 | 04:06 PM
Heylookits shawn's Avatar
you dont need to re weld it. you can just use a die and cut new threads after you chop it. honestly the throw wont be any shorter, the **** will just sit lower. unless you are talking about chopping the pivot ball thing off and moving that
JerkzEm1
May 16, 2005 06:34 PM
sohctodohc
Oct 3, 2004 06:43 PM
Nothing.Special
Jul 8, 2004 08:23 PM
wdskuk
Feb 13, 2004 03:54 PM
92CIVICCX
Jan 20, 2003 11:10 AM
