How to remove shifter
I want to chop my shifter but im a noob and i was wondering if someone could write a how to so i can take it out and chop it and then reweld it. thanks guys greatly appreciate it.
Re: How to remove shifter (slow_redcivic)
take off shift ****, take out the 12 mm bolt that holds the shift link to shifter. Then take out the 2 10 mm bolts that hold the shifter in place.
Re: How to remove shifter (-Gambit-)
OK i took off the shift **** and removed the 2 center peices and there is that black thing at the bottom of the shifter how do i take that out to get to those bolts?
its easy, just follow the shift links back to the shifter, Take out the bolts that hold the shift link on. Then follow the shifter up and you will see the 2 bolts you take out to drop your shifter
alrighty thanks guys i'll see if i can find pics. i would go check it out but it snowed 6" here and i just got home so its really wet under my car.
Re: How to remove shifter (DYRcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DYRcivic »</TD></TR><TR><TD CLASS="quote">http://importnut.net/shifter.htm
here you go man step by step</TD></TR></TABLE>
thank you. You just dont have to drop the shift links from the tranny for what you are doing
you dont need to re weld it. you can just use a die and cut new threads after you chop it. honestly the throw wont be any shorter, the **** will just sit lower. unless you are talking about chopping the pivot ball thing off and moving that
Nothing.Special
07-08-2004 08:23 PM
wdskuk
02-13-2004 03:54 PM
