swapping obd1 sir 2 b16 into 96 hatch
do i need to use the conversion harness some one told me that all i need is the obd 1 ecu. i know there is alot of wires u have to run. The package im getting is from hmotorsonline.com and it includes
B16A 92-95 (SiR-II) Complete Change Over
Price: $ 2250.00 Plus shipping and handling
Availability: In stock and ready to go
- Motor
- Hydraulic Tranny (S21, Y21)
- ECU (P30)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300) -i am goin to get the lsd!
- Motor
- ECU (P30)
- Shift Linkage
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
Your OBD1 should work fine with the ECU that is being supplied to you from the source of engine. Call them and ask if it is compatible with your OBD1 computer.
P72,P28,P30,P61,P08J,P30J,P72J
These are the ECU's which work with the OBD1
Edgey - DEMOS (1999) 00 - Bone Frequency (Bio Fusion Mix).mp3 [128Kbps] (06:10)
You will need a jumper harness to plug up your new OBD1 ecu. OBD1 and OBD2 computers have different sized plugs. Try Skunk2 or LoCash Racing for a conversioin harness. Good luck with your swap.Also, your driver side motor mount is going to be different than the one coming with your swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solo1B16Hatch »</TD></TR><TR><TD CLASS="quote">You will need a jumper harness to plug up your new OBD1 ecu. OBD1 and OBD2 computers have different sized plugs. Try Skunk2 or LoCash Racing for a conversioin harness. Good luck with your swap.Also, your driver side motor mount is going to be different than the one coming with your swap. </TD></TR></TABLE> That ecu should be obd 1 if it is do i need the jumper harness still?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by young noob »</TD></TR><TR><TD CLASS="quote">and you have a hatch, so you will need to wire v-tec, goodluck with it, might want to look into a p28</TD></TR></TABLE> p28 is gsr right? wiring v tec consists of?
your car is a 96 hatch, its an obd2a vehicle, but your putting an obd1 into it, so you need to get a conversion harness from like jdmshit.com so you can plug an obd1 ecu/motor into your obd2a vehicle, a p28 is a chip-able ecu, so you can do some minor "tuning" until you can get hondata or something, but make sure you get the right jumper harness, caz they make them for 96-98, and 99-00 which are different, and just search for wiring vtec, it will save me some typing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skiracer8148 »</TD></TR><TR><TD CLASS="quote"> p28 is gsr right? wiring v tec consists of?</TD></TR></TABLE>
GSR is a P72
92-95 Civic EX is a P28
Check hybrid forum for wiring info or do a search and it will come up
GSR is a P72
i would get a 96-98 EX manual engine harness, a obd2-1 jumper and a p30 ecu
you can use the stock DX harness but you will have to rewire stuff, i find it easier to use the EX harness.
also you need a 99-00 SI rear motor mount and 99SI timing belt bracket(the one that bolts to the motor itself)
your stock top tranny mount and timing belt mount will work fine
SpecVtec
May 17, 2004 02:26 PM
