oil usage question
Old Dec 26, 2005 | 11:52 PM
abda53's Avatar
Default oil usage question
did a search on here and couldnt find anything..
i heard this engine burns oil pretty fast, this weekend i drove about 300 miles (1 1/2 hours each way) i started out good on oil, about half way back home, i noticed i was pretty low on it.. i was driving around 80-90mph the whole time (regular traffic speed out here).. just wondering is that common oil usage. and if theres anything to "help" it
Old Dec 27, 2005 | 12:34 AM
uNF$@#!'s Avatar
Default Re: oil usage question (abda53)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abda53 &raquo;</TD></TR><TR><TD CLASS="quote">did a search on here and couldnt find anything..
bullshit.
Old Dec 27, 2005 | 02:27 AM
Bbasso's Avatar
Default Re: oil usage question (uNF$@#!)
» Search Results
Your search for oil returned 17 results. Combined...
So back off you sick maniac!
Must be something wrong with the search.
Old Dec 27, 2005 | 05:36 AM
jond's Avatar
1 quart every 3,000 miles is around normal for a high mileage ITR.
Thats about what I burn now with 100,000 miles.
Old Dec 27, 2005 | 05:58 AM
1GreyTeg's Avatar
Default Re: oil usage question (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">
» Search Results
There is nothing wrong with it. They are just working to upgrade it and at the moment it doesn't easily search deep archives. To do that you'd need to use a specific users name for a post you remember.
I'm told that it will be fixed soon.
Old Dec 27, 2005 | 05:59 AM
The Tech-1's Avatar
Default Re: oil usage question (jond)
Also depends on how often/ how long you are in VTEC for..or am I wrong?
Old Dec 27, 2005 | 06:28 AM
abda53's Avatar
Default Re: oil usage question (The Tech-1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">They are just working to upgrade it and at the moment it doesn't easily search deep archives.</TD></TR></TABLE>
thanks.. the search feature on here is one that i personally dont like using.
and yes uNF$@#! i did find results and i did look through the readme sections.. but nothing specific on what i was asking. but then again, maybe im just not as smart as you
Old Dec 27, 2005 | 07:07 AM
jond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Tech-1 &raquo;</TD></TR><TR><TD CLASS="quote">Also depends on how often/ how long you are in VTEC for..or am I wrong?</TD></TR></TABLE>
Yeah, but not as much as you think.
After 3 hours on the track, I think I burned around 1-1.5 quarts.
So just hitting vtec a lot on the street I dont think would make much of a difference.
Old Dec 27, 2005 | 07:09 AM
abda53's Avatar
yeah i hardly hit vtec.. i think i hit it once the entire trip. im going to watch the oil levels more closely now and see.
Old Dec 27, 2005 | 07:29 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abda53 &raquo;</TD></TR><TR><TD CLASS="quote">i heard this engine burns oil pretty fast, this weekend i drove about 300 miles (1 1/2 hours each way) i started out good on oil, about half way back home, i noticed i was pretty low on it.. i was driving around 80-90mph the whole time (regular traffic speed out here).. just wondering is that common oil usage. and if theres anything to "help" it</TD></TR></TABLE>
Yes, burning oil is common in the ITR. On public roads, it can be one quart every 1-3K miles; some engines don't burn any. On the racetrack, it can be one quart every 100-200 track miles.
If you're saying that you were down by a quart after 150 miles, that sounds like an unusually high amount. If you're saying that you were down by half a quart after 450 miles, that's not so unusual.
Old Dec 27, 2005 | 07:32 AM
abda53's Avatar
it was the later i think. im going to watch it more closely over the next week or two and see.
Old Dec 27, 2005 | 07:35 AM
The Tech-1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond &raquo;</TD></TR><TR><TD CLASS="quote">
Yea after 16 hours worth of high speed highway driving I was down a quart - 1.5
Old Dec 27, 2005 | 07:37 AM
totsie7944's Avatar
Default Re: (abda53)
yea keep up on that man. If there is a problem I would get it fixed before anything else goes wrong. Good luck man.
Old Dec 27, 2005 | 09:03 AM
abda53's Avatar
Default Re: (totsie7944)
i read this here https://honda-tech.com/zerothread?id=748910 but wasnt quite sure
if you use a oil pressure gauge, will it tell you if the oil is alittle low, or will it tell you if its very low/almost gone?
Old Dec 27, 2005 | 09:07 AM
D-Rob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abda53 &raquo;</TD></TR><TR><TD CLASS="quote">i read this here https://honda-tech.com/zerothread?id=748910 but wasnt quite sure
if you use a oil pressure gauge, will it tell you if the oil is alittle low, or will it tell you if its very low/almost gone?</TD></TR></TABLE>
You won't see much difference in oil level from a pressure gauge.
Just get out, pop the hood, and check the oil every time you get gas.
Old Dec 27, 2005 | 10:04 AM
abda53's Avatar
thats what ive been doing actually after someone else suggested it.
i wasnt sure about the guage though.. im NA so im thinking if i check the levels regularly i really dont need it
Old Dec 27, 2005 | 04:08 PM
Lo-Buck EF's Avatar
as long as you dont burn oil like rob and i. then your ok. im up to 1/2 quart per 20 min session on track.
&lt;-----------crossing his fingers about this valve seal replacement
sohcvtec91hatch
34
Mar 24, 2007 12:15 PM
Norwegian
Honda S2000
10
Jan 7, 2007 02:27 PM
phantom_bcw84
Sep 12, 2006 07:21 AM
return_2020
Dec 13, 2004 07:14 AM
io_burn
Nov 23, 2002 02:32 AM
