timing mark
Old Dec 26, 2005 | 03:12 PM
sohc-8's Avatar
Default timing mark
Hi everyone, i have a question about the ignition timing marks. I checked the ignition timing on my 98 civic and i can't see the red line, i only see the white line.
I know the white line is for TDC and the red one for ignition timing . So my question is Do you guys see the red line when you're checking the timing and if not , can i use the white line instead cause thats what i see.
also im using a craftsman inductive timing light.
Old Dec 26, 2005 | 04:19 PM
ntrider's Avatar
Default Re: timing mark (19civic98)
whats up man. I see that you are new to the forum so I am going to help you out. check this link out I found by searching, in the upper right part of this web site, https://honda-tech.com/zerothread?id=1363201.
Besides the white mark there are three others that are on the cramk pulley. look over the website. If you have any other question search the site using the search function.
good luck
1990civicdx
Jul 17, 2018 06:13 PM
blackbndt
Oct 4, 2009 10:20 AM
jdurston
Jun 9, 2004 05:30 AM
King_j
Aug 14, 2003 07:40 PM
integrasi
Jul 23, 2003 04:26 PM
