Couple more n00b questions.
1. What is the size/measurement of the nuts that hold the intake manifold on? I lost one of them and can't find it for the life of me.
2. Any suggestions on where to wire up my newly installed boost gauge? I've already set up the pressure hose, but now I need to light it. The gauge is mounted in my left tweeter cover. (Dremeled it out.) Anyone know where a nearby Pos. and Ground is that I can use?
the IM nuts are 13mm maybe 12mm deff one if the 2. some correct me if im wrong.
and for the boost gauge just run the + into the clock radio fuse or sumn like that and for the ground just unbolt a nut fasten it to that. make sure there no paint on the metal. i could get more detailed but its late and im tired... good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N »</TD></TR><TR><TD CLASS="quote">the IM nuts are 13mm maybe 12mm deff one if the 2. some correct me if im wrong.
The wrench it uses is 12mm, the size of the threads is 8mm
