B16 t67, which A/R should I go with?
Old Dec 22, 2005 | 06:37 PM
92cxturbo's Avatar
Default B16 t67, which A/R should I go with?
Hey guys,
I mostly search when I need info. and read posts. This time I couldn't really find what I was looking for so... I need some opinions on what A/R I should get. I'm looking to make around 550hp and thinking about getting t3/t67. Since its a b16 I know im probally gonna have to rev it to about 9500 to get a good power band out of it. Do you guys think I should get the .63 or .83 A/R? I'm not worried too much about lag, I used to have a t3/to4e .57 .82 a/r. on a stock b16 and made 280hp before. I'm just not sure if the .63 will make power at that rpm.
Engine Info.
benson sleeved b16a block
83mm CP pistons
Eagle rods 3/8 bolts
portflow springs and retainers
Skunk2 valves, and IM
one fab non a/c mani
Old Dec 23, 2005 | 06:39 AM
92cxturbo's Avatar
Default Re: B16 t67, which A/R should I go with? (92cxturbo)
Old Dec 23, 2005 | 06:56 AM
s2kdre's Avatar
.63 a/r
Old Dec 23, 2005 | 06:58 AM
B00STFREAKS's Avatar
The .63a/r will be more then enough for only 550whp on that turbo..
Old Dec 23, 2005 | 07:39 AM
92cxturbo's Avatar
Default Re: (B00STFREAK)
I know the .63 will support that much power, but what I'm wondering is will it make power past 8500 or 9000?
Old Dec 23, 2005 | 07:50 AM
Default Re: (92cxturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92cxturbo &raquo;</TD></TR><TR><TD CLASS="quote">I know the .63 will support that much power, but what I'm wondering is will it make power past 8500 or 9000?</TD></TR></TABLE>
yes
Old Dec 23, 2005 | 03:02 PM
92cxturbo's Avatar
All the dyno's that Ive seen with the smaller .63 a/r seem to fall off around 8800. I would really like to make power to 9500 atleast.
Old Dec 23, 2005 | 03:08 PM
Boostfed's Avatar
New User
.82 A/R My old B16A had a T3/60-1 with .82 A/R made 500whp 25psi then later I got the Full Race T4/T67 with .68 A/R BUT that is T4 full spool 6500 and made power to over 10,500 RPM
T3/60-1 chart here
https://honda-tech.com/zerothread?id=311514
T4/T67 chart here
https://honda-tech.com/zerothread?id=1069197
Old Dec 23, 2005 | 03:29 PM
tokesGTR's Avatar
Default Re: (Boostfed.com)
https://honda-tech.com/zerothread?id=1377270
If a .63 A/R will pull to 9500 no problems on Servion's 1.8L motor, it'll do 9500+ on a B16 without issue. .82 A/R is going to give you additional lag with minimal top end gain.
Old Dec 23, 2005 | 03:36 PM
Boostfed's Avatar
New User
Default Re: (tokes1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tokes1320 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1377270
If a .63 A/R will pull to 9500 no problems on Servion's 1.8L motor, it'll do 9500+ on a B16 without issue. .82 A/R is going to give you additional lag with minimal top end gain.</TD></TR></TABLE>
UH going from a .63 A/R to an .82 A/R is going to spool maybe 300-500rpm slower BUT will give 20-30whp gain! Also Full Race and Jeff Evans had done some testing on a GT35R with .63 A/R and then .82 A/R and spool they state was identiacal BUT power gains were significant.
Old Dec 23, 2005 | 03:40 PM
tokesGTR's Avatar
If he only wants 550 WHP i'll take the .63 A/R and throw another pound of boost at it to compensate for what the .82 A/R hot side might make. The only tests I've ever seen were between a .63 A/R SC61 and a .82 A/R GT35R that Jack @ P1 did, and even comparing a journal bearing to a ball bearing turbo the lag added was fairly significant.
Heck at "only" 550 WHP I'd probably skip on a T3/T67 all together and "step down" to an SC61, maybe a .63 A/R GT35R or even a GT30R and take all the added powerband I can get, which is the focus of his initial post.
Old Dec 23, 2005 | 03:52 PM
Boostfed's Avatar
New User
The least amount of backpressure is really what you want for max power and efficiency.
Old Dec 24, 2005 | 09:54 AM
92cxturbo's Avatar
Thanks for all the replays guys! my goal isnt that I only want to make 550hp I just fell it would be a good starting point, and then be able to make more later down the road. I thought I read in a post that Servion was gonna switch to the .82 A/R.(I just realized Ive been sayin .83, oops ) Does anyone know if he has yet? I would really like to see a comparision on that.
If want I want is least amount of back pressure which makes sense to rev to though's rpm's then would I be better off just getting the H.O.?
Old Dec 24, 2005 | 10:01 AM
IHaveTurbos's Avatar
Yeah if your going to go with the .82a/r you should just step up to the P trim (H.O.).
Old Dec 24, 2005 | 11:41 AM
Boostfed's Avatar
New User
Default Re: (TurboElements.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboElements.com &raquo;</TD></TR><TR><TD CLASS="quote">Yeah if your going to go with the .82a/r you should just step up to the P trim (H.O.).</TD></TR></TABLE>
Old Dec 24, 2005 | 02:51 PM
92cxturbo's Avatar
I think thats what I am gonna do. thanks guys!
Old Dec 25, 2005 | 01:28 PM
doc's Avatar
doc
I'm working a B16 project, too. So this thread is very informative for me, cause i'm still unsure which AR i shoud use.
Can you please explain what the advandace of the P Trim will be? (compared to the Stages 1-5)
TIA,
Doc
Old Dec 25, 2005 | 01:45 PM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">
UH going from a .63 A/R to an .82 A/R is going to spool maybe 300-500rpm slower BUT will give 20-30whp gain! Also Full Race and Jeff Evans had done some testing on a GT35R with .63 A/R and then .82 A/R and spool they state was identiacal BUT power gains were significant. </TD></TR></TABLE>
Jeff's test is not going to be the same if they used a 67. Ball bearing's are going to make a big difference in this case IMO. I can guaranty it will be at least a 500rpm difference. If you will never want more then 500-550HP, go with the .63.
And il agree if you only want 500HP get the SC-61 and spend the extra cash on an victor x IM or something I dont know if you have ever driven with a 67 but the power comes in like you would not believe (all of a sudden), the sc-61 is a smother transition and is much more manageable on the streets IMO.
Oh I have an sc-61 an non-ac one-fab manifold FS right now too. Both brand new, PM if interested.
Happy Holidays
Old Dec 25, 2005 | 07:24 PM
Boostfed's Avatar
New User
Default Re: B16 t67, which A/R should I go with? (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">
Happy Holidays </TD></TR></TABLE>
Yeah I have driven with a 67 before!
Old Dec 26, 2005 | 10:51 AM
i my honda
Global Mod
Default Re: B16 t67, which A/R should I go with? (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I have driven with a 67 before! </TD></TR></TABLE>
I was referring to the thread poster in that second paragraph. Sorry if that was not clear.
Old Dec 26, 2005 | 10:54 AM
Boostfed's Avatar
New User
I was referring to the thread poster in that second paragraph. Sorry if that was not clear. </TD></TR></TABLE>
I know!
Old Dec 31, 2005 | 03:27 PM
swapit's Avatar
im, running a b16 with a sc61 w/63 ar and i made 595 on 28lbs.im goin to the t67 ho for next season.heres the graphhttp://forums.evans-tuning.com/viewtopic.php?t=2475
Old Dec 31, 2005 | 04:03 PM
uglyasscivic's Avatar
Default Re: B16 t67, which A/R should I go with? (swapit)
T3/67 H.O. .82ar 15 psi revin to 10k
http://neptune.evans-tuning.co...t=112
TimKennard
Feb 5, 2010 06:05 AM
GetawayInMoscow
Mar 4, 2007 11:56 AM
vestalfootball72
Apr 11, 2006 03:03 PM
jdmcoop
Mar 23, 2006 01:50 PM
Tex Blackwell
Jul 30, 2004 06:01 AM
