sc61 turbo on b16 what powerband?
Guest
Posts: n/a
Im considering using a sc61 turbo on my stock b16 with CTR cams.
from what ive looked at its going to be a little bit higher end power.
I am wondering what you guys are making full boost by.
I am looking for boost at 4k to redline. Am i looking for something i cant get?
my power goals are 250whp+ with reliabilty at the most important aspect.
Re: sc61 turbo on b16 what powerband? (vestalfootball72)
If you looking for 4k-redline, then get a t3/t4 with an A/R 63, and 60trim, I don't have a sc61, but my friend did, and it was at full boost at 5500, and it was laggy on his b16. I don't suggest it unless you drag a lot, and plan on going bigger than 500hp. That's might opinion, I'm sure someone else will add in theirs.
Guest
Posts: n/a
Where can i find a t3/t4 with the A/R 63 and 60 trim? I have been looking around for turbo's but cant really find a good site to get them from. What kind of power am i looking at with a sc34 at 8-10psi vs a t3/t4?
I found 3 people in 1 minute in the marketplace right here on h-tech that had the 60 trim..... look a little harder.
Re: sc61 turbo on b16 what powerband? (B18C1CYA)
Re: sc61 turbo on b16 what powerband? (12SEC CIV)
https://honda-tech.com/zerothread?id=1564150
13psi. bone stock b16a2 motor
on 7.5psi it made 250/170 and full boost was 5500 as opposed to 6000@13psi. it doesnt really wake up till about 6500 tho
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 »</TD></TR><TR><TD CLASS="quote">sc61 is looking a little bit to laggy for me, any dynos of the t3/t4 or sc34 ect on stock b16's</TD></TR></TABLE>
Read up more on turbos. An SC61 is classified as a T3/T4 turbocharger because it uses a T4 compressor side mated to a T3 turbine and wheel. "T3/T4" is an overly generic term and really doesn't describe the power output or powerband of a turbo at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 »</TD></TR><TR><TD CLASS="quote">BB SC61 FTW!!!</TD></TR></TABLE> A little expensive for most of HT users, just look into turbonetics t3/t04 turbo, but they do make a 60-1, and 62-1 turbo, but to much for your HP goal. Look into turbonetics, garrett, they are cheaper than precision, plus turbonetics offers a good waranty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote">sc44 would be better , or a gt28rs </TD></TR></TABLE>
I personally have a SC61 on my B16 setup (not running yet tho). However, for your goals, a much smaller turbo would be best.
I've got a t3/t4 .63ar 57 trim made 256whp and 178wtq @ 9psi... so just get that turbo... most drag and rev hard kits came with this.. so... that should meet your goal of 250 hp.. later mike
i HAS questions ?
Re: (slowhonduh93)
What about a .48 trim .60 A/R T3/T4 on a B16, like the one I have sitting in my garage?
Off topic, my cousin used to go to Vestal/play football there.
GetawayInMoscow
03-04-2007 11:56 AM
92-LS-Civic
03-13-2005 09:05 PM
