Stripped lugnut
Old Dec 19, 2005 | 03:25 PM
SiMateoAko's Avatar
Default Stripped lugnut
Like a moron I bought lugnuts at Autozone. Today while trying to put new tires on my car one of the bolts stripped. I tried everything I could think of to get it of. I tried using my impact wrench and nothing happened. I'm certain I don't know how to use that thing properly. I also tried using that old trick of hammering in a notch on the bolt with a screwdriver and then trying to get leverage and turn the bolt that way. I ended up just tearing the bolt to hell and back.
I do not have access to any welding equipment, so I am unable to weld a bar to it and do it that way.
I do have air tools but I've never used them. I'm not opposed to using them to do this though with proper instruction.
Can anyone help me? How have you removed a stripped lugnut before?
Should I epoxy (JB Weld, etc.) a tire iron to the lugnut and try that?
Old Dec 19, 2005 | 03:38 PM
linx's Avatar
Default Re: Stripped lugnut (SiMateoAko)
get a socket that barely fits and hammer it on then use a large ratchet and take it off(impact socket works best). hope that helps
Old Dec 19, 2005 | 03:43 PM
SD_Lurker's Avatar
HT White Ops
They sell special sockets for problems like that. I know for a fact that snap on has them but I am unsure who else makes them. You hammer the socket on and it will screw right off. Good Luck. Let me know if you need more info.
Old Dec 19, 2005 | 03:48 PM
Autoworks's Avatar
Default Re: Stripped lugnut (nicks_jdmstyle_ef9)
Either...
A. Beat a socket onto it and just turn it off. Should be very easy provided that the outside is just stripped and its not actually cross threaded.
B. Since you have air tools, if you have an air hammer/chisel, just chisel it, it will start to turn easily.
I have locks and stripped lug nuts removed at work all the time. Option A is what I end up doing 80% of the time, B about 15%. the other 5% you just get down and dirty and straight tear the bitch up getting it off, usually end up replacing the stud too.
Snap on does in deed sell a tool just for removing stripped bolts., we just don't use it because of otion A & B working just fine usually
Old Dec 19, 2005 | 05:56 PM
SiMateoAko's Avatar
Default Re: Stripped lugnut (linx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by linx &raquo;</TD></TR><TR><TD CLASS="quote">get a socket that barely fits and hammer it on then use a large ratchet and take it off(impact socket works best). hope that helps</TD></TR></TABLE>
I tried doing this with two sockets. I first did it one size smaller and it stripped again. Did it with another size smaller and (you guessed it) it stripped again.
I'll try the air tools tomorrow. I'll try either the air chisel or the impact wrench.
At the very least I'll probably be able to tear it off. The metal was pretty flimsy, so I'm guessing I can get it off with a little work.
Old Dec 19, 2005 | 06:09 PM
31flavorscivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks_jdmstyle_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">They sell special sockets for problems like that. I know for a fact that snap on has them but I am unsure who else makes them. You hammer the socket on and it will screw right off. Good Luck. Let me know if you need more info.</TD></TR></TABLE>
Craftsman
Old Dec 19, 2005 | 06:33 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: Stripped lugnut (31flavorscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic &raquo;</TD></TR><TR><TD CLASS="quote">
Craftsman </TD></TR></TABLE>
Old Dec 20, 2005 | 09:07 AM
AZTEKEF9's Avatar
Default Re: Stripped lugnut (DieMaster)
man i feel ur pain.....i stipped the nut and the bolt on the hub.....and when i try to do it the whole thing turns.....the stud stripped at the hub.....so i need to drill it out....spend $50 on drill bits and no luck......i got one more thing...which is to take it to a machine shop and use one of those wet drill things and drill it out....wish me good luck....and good luck to ya
Old Dec 20, 2005 | 11:34 AM
SiMateoAko's Avatar
Default Re: Stripped lugnut (AZTEKEF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZTEKEF9 &raquo;</TD></TR><TR><TD CLASS="quote">man i feel ur pain.....i stipped the nut and the bolt on the hub.....and when i try to do it the whole thing turns.....the stud stripped at the hub.....so i need to drill it out....spend $50 on drill bits and no luck......i got one more thing...which is to take it to a machine shop and use one of those wet drill things and drill it out....wish me good luck....and good luck to ya</TD></TR></TABLE>
I just spent an hour trying to get it to budge with an air chisel. I just made it worse.
I think I'm just going to drive it to a tire place and have them get it off. Stud be damned.
Or I guess I could just get some drill bits and try to drill the bolt off. yeah, I like that option better. More fun.
Old Dec 20, 2005 | 12:30 PM
AZTEKEF9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiMateoAko &raquo;</TD></TR><TR><TD CLASS="quote">
Or I guess I could just get some drill bits and try to drill the bolt off. yeah, I like that option better. More fun. </TD></TR></TABLE>
oh oh.......i sis take it to a wheel place....and they could not do anything........
Old Dec 20, 2005 | 01:05 PM
John McClane's Avatar
did you take it to some piece of **** hole in the wall?
take it to a reputable wheel/tire shop theyll charge ya a couple bucks but its worth it.
oh ya, buy a new wheel stud from honda.
Old Dec 20, 2005 | 01:26 PM
AZTEKEF9's Avatar
Default Re: (RockTheMullet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockTheMullet &raquo;</TD></TR><TR><TD CLASS="quote">did you take it to some piece of **** hole in the wall?
oh ya, buy a new wheel stud from honda.</TD></TR></TABLE>
yea....kinda... the wheel got a lil damaged...so i'll be taking it to tru-wheel in west hollywood....
Old Dec 20, 2005 | 01:50 PM
SiMateoAko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZTEKEF9 &raquo;</TD></TR><TR><TD CLASS="quote">oh oh.......i sis take it to a wheel place....and they could not do anything........</TD></TR></TABLE>
I took it to Big-O and they told me it would cost $75 to drill the stud out. I can either spend a bunch on drill bits or just pay these guys to do it for me.
I'm going to do it tomorrow b/c I don't have the time or patience for this type of thing right now. They also said they can replace the stud for $5, so that's not bad either.
Anyway, this crap sucks. All of the money I saved by buying the rims with the wheels is now gone.
Old Dec 20, 2005 | 02:17 PM
AZTEKEF9's Avatar
Anyway, this crap sucks. All of the money I saved by buying the rims with the wheels is now gone.</TD></TR></TABLE>
wow....i should try Big-O....
honda_S
Feb 16, 2010 07:33 PM
00DC2
Jul 22, 2009 06:18 PM
tree fingers
12
Sep 19, 2008 04:18 PM
a1320addict
Aug 26, 2006 05:19 PM
Adachi
Mar 3, 2003 08:04 PM
