slipping out in 5 gear HELP
Old Dec 14, 2005 | 08:43 PM
Novtecdohc's Avatar
Default slipping out in 5 gear HELP
just turbo my b16. now when im on the highway it slip out of 5 gear. never had a problem when it was na. other then one of my axle going bad it starting slipping out of 5 gear. fix the axle and now it slip in 5 gear only.
Old Dec 14, 2005 | 08:46 PM
primeredbeast's Avatar
Default Re: slipping out in 5 gear HELP (Novtecdohc)
sounds like you got a syncro going out now listen this was happening to me so i tried syncromesh tranny fluid, gear hasnt popped back out in 6 months give it a try hope it helps
Old Dec 14, 2005 | 08:51 PM
Novtecdohc's Avatar
Default Re: slipping out in 5 gear HELP (primeredbeast)
i barley use 5 gear. how can the syncro be going bad? the motor and tranny is from a 99 si under 60k
Old Dec 14, 2005 | 08:52 PM
B18 CYA's Avatar
have enough tranny fluid?
Old Dec 14, 2005 | 08:58 PM
does it grind at all when it goes into gear? other than that if the tranny fluid is filled its got to be your syncro
Old Dec 14, 2005 | 09:00 PM
Novtecdohc's Avatar
no grind, how do u check the fluids? might change the fluids put syncromeash
Old Dec 15, 2005 | 12:37 AM
714phil's Avatar
Default Re: (B18 CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Novtecdohc &raquo;</TD></TR><TR><TD CLASS="quote">just turbo my b16. now when im on the highway it slip out of 5 gear. never had a problem when it was na. other then one of my axle going bad it starting slipping out of 5 gear. fix the axle and now it slip in 5 gear only.</TD></TR></TABLE>
This happened to me about 4-5 years ago.. i had a bad transmission seal where the intermediate shaft went into teh tranny.. which caused it to leak trans fluid.
I replaced the seal, topped it off with fluid and that problem hasnt happened to me since then.
The problem is most likely that you are low on trans fluid.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">have enough tranny fluid?</TD></TR></TABLE>
Old Dec 15, 2005 | 05:59 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (STD ONEpointSIX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STD ONEpointSIX &raquo;</TD></TR><TR><TD CLASS="quote">
BINGO
Old Dec 15, 2005 | 08:36 PM
longuyen88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STD ONEpointSIX &raquo;</TD></TR><TR><TD CLASS="quote">This happened to me about 4-5 years ago.. i had a bad transmission seal where the intermediate shaft went into teh tranny.. which caused it to leak trans fluid.
I had this happen to me while I was on my way home from a road trip. b16 in 4th gear going 70mph for 2 hrs sucks!
Old Dec 15, 2005 | 08:54 PM
adictionbass's Avatar
Default Re: (longuyen88)
as far as i know, synchros dont hold a tranny in gear
jdm94eg's Avatar
same thing happend to me and that solved it
Old Dec 15, 2005 | 09:09 PM
mattcivic's Avatar
Default Re: (jdm94eg)
i had the same prob fluid was low filled it still did it pulled tranny did a rebuild and found that the sleeve for 5th and revers had some nice burs on it i took it to work cleaned them off realy nice lsd syncros bearings seals and i have the smoothest tranny in town now. but its most likely low fluid ive had a few budddies with this prob.
deejae
Nov 16, 2013 02:39 PM
MrExclusive
Feb 4, 2010 07:52 AM
dc2[HI]
Aug 7, 2008 11:03 AM
tcontesh
Apr 11, 2006 11:53 AM
tyflip2
Nov 10, 2003 09:52 PM
