ls/vtec vtec problems
Old Dec 11, 2005 | 02:05 PM
lsvtec1.9lcrx's Avatar
Default ls/vtec vtec problems
ok guys i have a question..i just finished my ls/vtec and when i threaded the oil hole i used about a 1/2" long plug and made that go about a 1/4" into the head.for some reason my vtec will not work..its like there is no oil for the vtec switch over.the solinoid is fine.is there a oil port that runs over to the other side that low in the head ??? i am thinking the plug was to long and is blocking an oil passage...anyone know ?????
Old Dec 11, 2005 | 11:02 PM
OMG B16's Avatar
Default Re: ls/vtec vtec problems (lsvtec1.9lcrx)
What size line did you use to run the oil from the block to the head?
Is your oil clean/full?
Check the vtec s.noid Screen?
Whats your oil pressure like?
Are you throwing any codes?
Old Dec 12, 2005 | 11:40 AM
its not thowing any codes at all.Runs perfect..i used the 4an kit off the oil pressure sensor but i do have a golden eagle 6an kit in front of me..i put a new vtec sel gasket with screen in when i built it..makes no sence..not sure on the oil pressure cause i dont have a gauge but everything is fine or it would of blown by now..it has 3 1/2 hours on the engine..i used a new oem itr oil pump to..
Old Dec 12, 2005 | 12:00 PM
OMG B16's Avatar
You might have enough oil pressure to run and drive the car, but that dosent mean you have enough for vtec. Put the -6an on and see if that works...
Old Dec 12, 2005 | 12:04 PM
West Werks's Avatar
Default Re: (Sick00SiCoupe)
I used to run 1/4" line. Never a problem. Most likely its not the size of the line.
Old Dec 12, 2005 | 12:10 PM
ya ,i am going to try the 6an and do from there..**** makes no sence..peaple use 4an all the time...
Old Dec 12, 2005 | 12:12 PM
so,is there no oil passage i might be blocking with that long plug i used ???
Old Dec 12, 2005 | 12:23 PM
fmrprojects's Avatar
Default Re: (lsvtec1.9lcrx)
yeah check that plug, it might be too long. the -4 line shouldn't be a problem, it should give you more oil pressure if anything.
Old Dec 12, 2005 | 12:31 PM
OMG B16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec1.9lcrx &raquo;</TD></TR><TR><TD CLASS="quote">so,is there no oil passage i might be blocking with that long plug i used ??? </TD></TR></TABLE>
If i had a head layn around i'd check for you, but i havnt taken mine off my car yet...
Modified by Sick00SiCoupe at 6:55 PM 12/13/2005
Old Dec 12, 2005 | 12:52 PM
NO,not comming out of the head..i screwed the plug about a quarter inch into the head..so its about 3/4 to 1 inch to the tip of the plug ,screwed in that oil port.
Old Dec 12, 2005 | 01:43 PM
OMG B16's Avatar
Damn, thats a little far, when i pull my head i'll check the passage, im going to screw it in untill it clears the face of the head, like 2mm.
Old Dec 12, 2005 | 03:57 PM
ya.i should of done that...besides the dam plug i had was long as hell..the golden eagle plug is realy short.i just hope the plug is not to long and blocking a oil passage..it will suck to have to take the head back off..lmk if you happen to see a oil port that low in the head..thanks man
Old Dec 13, 2005 | 02:28 PM
anyone have a b16 head laying around..??
Old Dec 13, 2005 | 02:42 PM
OMG B16's Avatar
I'll be pulling mine tomorrow, so i'll let u know.
Old Dec 13, 2005 | 02:56 PM
hell ya !!!..thanks alot..
Old Dec 14, 2005 | 12:45 PM
well i went today and put the golden eagle kit back on it..i also bought a oil pressure gauge and have it all hooked up ..its around 30 at 1400 rpm's around 50 at 2500 rpms..gets as high as 80 psi at times..dam cops were all over by my shop so i could not test drive it..i unscrewed the plug on the other side by the sel. and it has oil so its getting over there..maybe the sel. is bad..i can hear it click but maybe its not opening..beats me..i am going to get a new sel and see what happens..
Old Dec 14, 2005 | 01:51 PM
OMG B16's Avatar
Get that fixed man, i didnt have the time to pull my motor today, but i will start tomorrow.
Old Dec 15, 2005 | 04:47 PM
I got it now...thanks
4door hobo
Jul 30, 2007 07:53 PM
bigislandc2
Sep 2, 2006 10:37 PM
da9driver
24
Aug 25, 2005 01:00 PM
highcomp
Feb 9, 2004 12:32 AM
kasted1
Aug 20, 2002 09:16 AM
