STUMPED...Vtec
Old Dec 10, 2005 | 08:20 AM
TheIceMan's Avatar
Default STUMPED...Vtec
arite, i been having this problem for a couple of weeks now. im running an obd1 b16 in my hatch and vtec doesnt seem to want to cooperate with me. vtec usually engages at around 5k or so. well ill start the car and after about 1 or 2 minutes of driving, the check engine light will come on. once this check engine light comes on vtec will not engage. the car still runs normally and everything else is fine, just no vtec. i pulled the code and im getting cel 22...(vtec malfunciton) duhh....reset ecu and nuthing happened. i check my oil level everyday and drive around with atleast an extra quart in my trunk, so i know it has nothing to do with the oil. can you guys juss gimme a list of things to check, cause im kinda stumped...BTW...i checked vtec wiring and that all seems to be fine as well. THANK YOU
Old Dec 10, 2005 | 08:22 AM
TheIceMan's Avatar
Forgot to mention when i restart the car the light will turn off...but eventually it comes back on
Old Dec 10, 2005 | 08:43 AM
TheIceMan's Avatar
neone...???? ive searched this topic
Old Dec 10, 2005 | 08:45 AM
TheIceMan's Avatar
im sure if my topic was about how cool runnin open headers is....or here are pics, do u like my sparkily paint job.....or how many bitches i fuked in the bak of my civic, i would be getting alot more replies....God forbid somebody gives me some dam imput...i know theres some people with knowledge out there about actual technical questions
Old Dec 10, 2005 | 09:12 AM
SVOboy's Avatar
Try out the section for whatev car you have (crx or 92-00) the tech forums really don't get much love. I'd like to help, but I dun run vtec so I dunno, :-(
Old Dec 10, 2005 | 10:46 AM
SteveoBA8's Avatar
Default Re: (SVOboy)
Get yourself a dvom and check continuity from the vtec solenoid connector on the engine harness to the correct ecu pin and do the same for the pressure switch's positive wire( the other is the ground). Check the pressure switch for continuity also. there ya go man.
Old Dec 10, 2005 | 11:33 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: STUMPED...Vtec (SigleyEK)
The filter screen behind the VTEC solenoid can clog and cause your symptoms.
EGThang
18
Jun 6, 2008 03:26 PM
springfieldcivic
15
Jun 24, 2005 02:26 PM
05r1
16
May 20, 2005 08:21 AM
veilsides2000
Nov 27, 2004 11:18 PM
