Head work
Old Mar 14, 2002 | 09:41 PM
ryand16y8's Avatar
Default Head work
Has anyone with a SOHC Civic ever had headwork done? I have an 00' EX and it has all modified I/E/H and all that, and the speed shop told me to do some "head work" involving porting and polishing the head, and intake manifold; along with a "competition" valve angle cut. What is all of that? What are the pro's and cons? and they want 1,200-2,000 dollars depending on god knows what. They also said i can get up to 20 extra horses.... how does that sound? Are they B.S.'ing or is this really something i sould look into...?? How does all that sound? Anything will help!
Thanks!
Old Mar 14, 2002 | 10:52 PM
rainforest's Avatar
Default Re: Head work (ryand16y8)
20 is alot but the teen's can bee seen with head work... and no there are no real problems with reliability with head work unless you get into milling alot...
Old Mar 15, 2002 | 05:38 AM
jt-sport's Avatar
as my experience with D Serries engine . I did the head work by my self ,including ported, polished , 3 angle valve jobs and milling the head for compression spec up. Thats all gain arround 10 Hp from the standart head. But the pro speed shop always did the port jobs with CNC ,they'll make much more better than hand work (just like i ussually did). I think that ain't bullshit if they says arround 20 hp gain.
JGenginedynamics, Endyn ,DPR, was the pro for this jobs
Old Mar 15, 2002 | 05:50 AM
Spade's Avatar
I wouldn't be paying $2,000 check http://www.portflow.com and get a ball park.
Old Mar 15, 2002 | 06:17 AM
Kamin's Avatar
what shop ryan? (im in tucson)
dont spend no god damn 2000$ if your gonna spend that, spend 2500 and do a motor swap.
check portflow.com and email scott byars at collective racing. he has a good place that does alot of head work. http://www.collectiveracing.net
[Modified by KAMiN, 7:19 AM 3/15/2002]
Old Mar 15, 2002 | 07:46 AM
fsp31's Avatar
Default Re: Head work (KAMiN)
I agree. That's a crazy price to pay for SOHC head work. First of all, you can swap the SOHC head without even removing cams or adjusting valves. It takes a decent mechanic literally minutes to pull the head off. If you're familiar with torque specs, etc. Just pull the head yourself and take it to a reputable shop. Be careful though! There's a great shop locally that will do all that work for well under $1000, but you have to bring them the head.
Old Mar 15, 2002 | 01:31 PM
ryand16y8's Avatar
No check it out, it's over at Superior Racing Development (in tempe), and they said it would cost "anywhere" from 1,200 to 2,000 (new gaskets, work on throttle body, intake, exsaust, and valve trim) so i got a price quote because i want to chop the project up into pieces, so just to do the intake, and throttle body is only 450.00+\- and that include parts and labor. I would do an engine swap to a B series, but by the time i do that i could just buy a 00' Si for the price of labor and everything else. And they have seen numbers up to the 20's in an SOHC engine after perfoming this.
all_motor_mike
25
Aug 18, 2010 12:33 AM
CeeJayy
Apr 6, 2007 07:46 PM
itr187
Nov 14, 2003 10:45 AM
baonest
Jul 17, 2002 06:41 AM
ryand16y8
Mar 16, 2002 06:18 AM
