Best ecu for p72 head..
Old Dec 7, 2005 | 10:23 PM
juicy629's Avatar
Default Best ecu for p72 head..
just wondering what the best ecu for a p72 gsr head would be.. thanks
Old Dec 7, 2005 | 10:28 PM
debogsr's Avatar
Default Re: Best ecu for p72 head.. (juicy629)
I think alot more information is needed to answer this question.
like....... what motor this head is going on. If your going to use any type of EMS.
Old Dec 7, 2005 | 10:33 PM
juicy629's Avatar
Default Re: Best ecu for p72 head.. (debogsr)
its going onto a b18b1.. i have a chipped/socketed p28..but i plan on using a stock gsr intake.. smarter to get dif intake or keep it and stick with the p28?...
Old Dec 7, 2005 | 10:49 PM
Lauj87's Avatar
a p72 is going to have a really low vtec cross over point. and it has secondaries, so if your not running a vtec controller or a GSR intake manifold you might lose some mid range power because a p72 also has secondaries. i think you can disable your secondaries with a vtec controller.
a p28 would be best if its chipped and tuned professionally. but if not i'd be safe and stick with the p72
Lauj87's Avatar
ahh **** repeated my slef ahahhaa
Old Dec 7, 2005 | 10:51 PM
juicy629's Avatar
Default Re: (Lauj87)
with that said can you recommend a intake manifold to match my p28?.. if the prices right ill just upgrade to that..
Old Dec 7, 2005 | 10:54 PM
Lauj87's Avatar
ebay, sk2 manifold carb exepmt 239.00 shipped! thats what im getting soon hopefully
Old Dec 7, 2005 | 11:00 PM
juicy629's Avatar
thanks man.. ill look into it
Old Dec 8, 2005 | 08:11 AM
fergy016's Avatar
Default Re: (juicy629)
you can always use the stock gsr im. The obd1 p72 is able to use the secondaries. You can chip the ecu and change the settings to get more power. Make sure to use a reputable tuner. You can do a street tune with a wide band o2 or better yet take it to a dyno and have a pro show you how. Just follow along with what they are doing. Don't be afraid to ask questions since your paying the outrageous rate per hour for this service.
solesthatgo
Apr 10, 2010 05:02 AM
watsvtecEK
Jun 29, 2006 12:11 AM
Luis_hp64
Sep 3, 2004 10:02 AM
petersayarath
Aug 16, 2004 09:50 AM
JDM DC2
Mar 12, 2002 07:32 PM
