Is the p72 ECU the best???
Ok i have a GSR head on a b16a block and the mechanic said that he was goin to give me a SOHC Vtec (p78) ecu and he was goin to fix it so i could go 8500RPM but u guys told me that the p72 was better for this aplication. If he fix the fuel/air ratio (along with the RPMs) in the computer do you think it may work right?
Re: Is the p72 ECU the best??? (Luis_hp64)
yup...if you're running the stock intake manifold stick to the P72. You can run the P28 (sohc vtec) ECU but it takes special tuning to get it to run a gsr manifold correctly since the ECU doesnt have IAB control.
