ecu help
Old Apr 9, 2010 | 03:13 PM
solesthatgo's Avatar
Default ecu help
what's better to run on my 94 obd1 gsr, p28 or p72 ecu. i have a b18c1 engine with blox stage 2 type b cams, supertech valvetrain, AEBS ported intake manifold wit 68mm throttle body port match, Hytec replica headers, and aem intake
Old Apr 9, 2010 | 03:38 PM
DumaDA's Avatar
Default Re: ecu help
well you drive a gsr, why wouldnt you use the gsr ecu? either way you need to get tuned with those mods
Old Apr 9, 2010 | 04:11 PM
GagnarTheUnruly's Avatar
The AEBS IM is single-stage, so p28 has everything you need (and is cheaper). You could keep your p72 or sell it and buy a p28 for a little profit.
Old Apr 9, 2010 | 04:15 PM
DumaDA's Avatar
does it matter that the p28 is built to supply for a 1.6L and the P72 is built to supply for a 1.8L? I would think that the ecu closest to his current motor would work better
Old Apr 9, 2010 | 04:27 PM
An untuned p28 would be a bad idea. I was assuming he would tune. If not, p72 is the better of the alternatives, but a tune is practically necessary with those mods.
boosting4life35's Avatar
p72 i had it on my obd1 gsr way faster then p28
Old Apr 9, 2010 | 04:30 PM
DumaDA's Avatar
thats what i was thinking, if he's going to use an ecu for tuning, either one will work fine, but if he's going to run a stock ecu on that set up (which wouldnt be recommended) might as well keep the gsr ecu since its closer to what he needs
Old Apr 9, 2010 | 11:58 PM
i had a chipped and tuned p28 but that burnt out. i asked my friends if they had a ecu for obdi gsr and my friend said he had one from his 95 gsr which was a p72. thats why i was a little confused. i plan to chip it and tune it so what do you guys recommend. p28 or p72
Old Apr 10, 2010 | 03:04 AM
Papa_Dios's Avatar
if you plan on chipping it go with he p28. Its easier to find one of those than a 94-95 gsr one anyway
Old Apr 10, 2010 | 05:02 AM
SIXTYdashONE
Nov 13, 2008 05:04 AM
fenix4o9
Jul 9, 2007 01:28 PM
Zion-I
Feb 12, 2006 09:32 PM
streetlights
Mar 19, 2003 10:41 PM
sicilian2k1
Aug 5, 2001 11:06 PM
