EP3 Door Panal Removal
Old Dec 7, 2005 | 08:29 AM
DOHC hatchback's Avatar
Default EP3 Door Panal Removal
I have a 03 si and there is something wrong with my drivers door speaker. I searched on How to remove the door panal, but nothing useful. Anyone know a website or tips to help.
Old Dec 7, 2005 | 09:31 AM
ace0fspades's Avatar
Default Re: EP3 Door Panal Removal (DOHC hatchback)
Haynes makes an awesome car book, it explains how to replace, change, and check pretty much anything in your car. I have one for 2001-2004 Civics. Here's what it says to do.
1. On manual window regulator equipped models, remove the window crank.
2. On Coupe and Sedan models, remove the inside door handle trim cover. Remove the mounting screws, then detach the handle rod and electrical connector.
3. Remove the pull handle trim cover, then remove the pull handle retaining screws. If equipped with power windows, disconnect the electrical connector from the window switch.
4. Remove the mirror trim cover.
5. Remove the door trim panel using a door panel removal tool.(or a screwdriver lol) Start from the bottom of the trim panel and work around the perimeter until all the fasteners have been released from the door
6. Lift the trim panel up to disengage the panel from the upper door ridge, unplug any electrical connectors, and remove the panel
7. For access to the door outside handle or the door window regulator inside the door, raise the window fully, then carefully peel back the plastic watershield.
I'm not sure if it will work with the Si, but it should be about the same.
Old Dec 7, 2005 | 11:04 AM
thanks man
Old Dec 7, 2005 | 01:40 PM
BarracksSi's Avatar
PM'd.
Old Dec 7, 2005 | 04:56 PM
Default Re: (DOHC hatchback)
no problem, let me know if it helped. :D
WHiTETYPEs
Aug 5, 2012 08:00 AM
96teggynonVtec
Feb 18, 2006 02:22 PM
TUNERboi
Sep 8, 2005 04:04 PM
thresher
Jan 16, 2005 10:47 PM
206civic
Jan 8, 2005 11:43 AM
