door trim removal
Old 01-15-2005, 09:05 PM
thresher's Avatar
Default door trim removal
how is the best way to remove door trim from an 88 hatch without breaking anything?
Old 01-16-2005, 10:27 AM
Forbesy's Avatar
Default Re: door trim removal (thresher)
you need to remove all of the various screws from around the panel first! from memory there will be two on the door handle/ window switch surround, one below the mirror (top inside corner) two holding the pocket (either end) two for the speaker cover, two or more behind the speaker cover, one in the door pull, and one on the outer edge next to b pillar!
Once they are all removed you should be able to pop the panel off all round the edges and slide upwards to release the top edge nearest the window pane!
HTH
Old 01-16-2005, 12:19 PM
thresher's Avatar
Default Re: door trim removal (Forbesy)
well forbesy from scottland, im talking about the door trim on the outside of the car, not the door panels on the inside. but thanks for the info
Old 01-16-2005, 12:23 PM
menkio's Avatar
pull.
Old 01-16-2005, 12:25 PM
thresher's Avatar
Default Re: door trim removal (menkio)
thats gonna insure it not to break if i just yank on it
Old 01-16-2005, 12:57 PM
menkio's Avatar
dood, remove the screws, and pull.. i know first time is hard, you might be nervous, you might be worried to pull to hard, to soon... we understand.. GO FOR IT... it takes a lot, but thats how it is..
just pull bro...
Old 01-16-2005, 01:34 PM
slowpokecivic's Avatar
heres a link <A HREF="https://honda-tech.com/zerothread?id=979961
" TARGET="_blank">https://honda-tech.com/zerothread?id=979961
</A>
Old 01-16-2005, 10:47 PM
thresher's Avatar
Default Re: door trim removal (HoNdAxCiViCxGs-R)
you know what mother ******? i went to search before i made a thread on this topic, go...try to find one...try to find a thread thats about this. so shut your ***.
96teggynonVtec
02-18-2006 02:22 PM
206civic
01-08-2005 11:43 AM
NtegraRacR05
09-15-2003 06:57 PM
JunkeeCrx
06-25-2002 12:07 PM
onyx00
09-05-2001 12:44 PM
Quick Reply: door trim removal
