HELP ON DOOR PANEL
Re: HELP ON DOOR PANEL (206civic)
take the door panel off. check if its off the rail..check your fuses..stuck somewhere....etc hopefully you find the problem
What kind of car? If its an EK, I'll tell you how:
-Remove sail panel (part inside the car where the side mirror is)
-Remove phillips screw from door handle pocket
-Pull lower cover off door handle/arm rest and remove 2 large phillip screws
-Remove speaker grill and remove 3 phillip screws down in the holes around the speakers
-Starting at bottom of the door, pull fairly firmly, and panel clips will start popping free.
-Work way up both sides, its clipped about 3/4 of the way up on both front and back of panel
-Remove wire harnesses from power door locks/power window controls
-Lift panel straight up, its clipped lightly onto sheet metal of door where the window comes up from
-Twist panel about 45 degrees and carefully pull door release handle through door panel.
-Done!
First time is a PITA, once you do it a few times, can be done in >5-10 minutes.\
Special K, you're an idiot, he just asked how to remove the door panel, by telling him "Just remove the door panel" you arent helping a whole lot.
-Done!
Re: HELP ON DOOR PANEL (Special-K-Coupe)
oh, you tak ethe screw off the door handle and the arm rest, unplug the wire if you have power doors and window and unclip the bottom and side and then pull off the door...
Sounds like what happened to mine. does it get about an inch from top and start clicking/grinding? Take your door panel off and look at the teeth on the track. You may need to rip some of the plastic out so you can see it better. JUST SLIT it so you can duct tape it later. good luck.
casper.hughes
10-12-2008 06:33 PM
eddie1681
02-24-2003 10:33 PM
