Running on two cylinders
Old Dec 5, 2005 | 04:03 PM
mugenhatchie's Avatar
Default Running on two cylinders
Hey guys,
On my other civic with a gsr in it i did a compression check. 270 across the board. It was running fine before the check but not it seems like it is running on two cylinders. It sounds almost like a harley and has no power what o ever!! I pulled the wires from the plugs and then pulled the plugs but forgo to unplug the injectors. What the expletive is up with it. The wires are good, replaced the plugs, coil is good, ignitor is good, injectors are good. I don't know WTF to do. I am completely lost. Your help would be great!!! Thanks.
Modified by mugenhatchie at 2:04 AM 12/6/2005
Old Dec 5, 2005 | 04:11 PM
SOHCD16y8's Avatar
Are you sure the firing order is right?
Old Dec 5, 2005 | 05:03 PM
Default Re: Running on two cylinders (mugenhatchie)
also the intake is unusally loud.
lsvtechatch92
Jun 25, 2007 07:55 PM
RotiEatter
Dec 20, 2006 12:40 PM
turboeg77
Jan 18, 2006 06:10 PM
b20ek
Jul 28, 2003 09:55 PM
Pengo
Jun 29, 2003 08:44 PM
