Rod knock....
Old Dec 4, 2005 | 08:24 PM
RedDC5's Avatar
Default Rod knock....
Disclaimer: Im not a newb, but Im still learning, please bear with me, I REALLY dont need flaming at a time like this.
Okay heres the deal, Im pretty sure I have rod knock, internal knocking sound coming from the bottom of the engine which increases with rpms. Is there anyway to fix this without spending an arm and a leg (maybe a bit, but not too too much) or getting another engine? or can this be diagnosed as another problem? Please help, Im jobless in school and I was already hurting for money before this!!! And once again, I really dont need flaming at a time like this..
Old Dec 4, 2005 | 08:36 PM
dohcVTECeg2's Avatar
Default Re: Rod knock.... (FerioEG)
you could just buy a new short block somewhere here in the classifieds and slap that bad boy on
Old Dec 4, 2005 | 09:16 PM
RedDC5's Avatar
bump, how much should that be for the infamously dinky d15b7? (daily)
Old Dec 4, 2005 | 09:17 PM
RedDC5's Avatar
dammit, i keep forgetting to watch my own post
Old Dec 5, 2005 | 07:29 AM
BiG Chris's Avatar
the real generic way to get it fixed is to pull the oil pan pop off all the rod caps and put in new bearings that are 1 step bigger than you have then close it all back up. this will get you by for a short while till you can do it right.
Old Dec 5, 2005 | 07:47 AM
turbotime's Avatar
i new d15b7 shouldnt be like more than $300 for EVERYTHING. I sold my full d16z6 for $500 and that was still working.
d15s are the bottom of the bucket int he honda world you can get a user coplete engine for cheap
Old Dec 5, 2005 | 07:55 AM
1point7db2's Avatar
Default Re: (turbotime)
I had a beater 90 integra that I delivered pizzas with, it began to rod knock, so I pulled the pan and put std size bearings in it. The #3 bearing was worn out, but it didnt spin, and it didnt tear up the crank. I didn't think it would last long, but I put over 10,000 hard miles on it and sold the car, I still see it running around town. The person that bought the car knew about the bearing when he bought it. He beats the **** out of the car everyday. He told me that it smokes so bad, he started running 80w90 gear oil in the motor! But it just wont give up!
Old Dec 5, 2005 | 12:03 PM
RedDC5's Avatar
Default Re: (BiG Chris)
Thanx to everyone for their help, I really appreciate you guys at a time as hectic as this in my life.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiG Chris &raquo;</TD></TR><TR><TD CLASS="quote">the real generic way to get it fixed is to pull the oil pan pop off all the rod caps and put in new bearings that are 1 step bigger than you have then close it all back up. this will get you by for a short while till you can do it right.</TD></TR></TABLE>
How hard is this to do, just wondering? and how long do you think that it will last? Also, how do I know if the bearing is worn? Please excuse my ignorance, Im learning on limited time and sources! Thanks in advance!
Old Dec 5, 2005 | 01:19 PM
BiG Chris's Avatar
Default Re: (FerioEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FerioEG &raquo;</TD></TR><TR><TD CLASS="quote">Thanx to everyone for their help, I really appreciate you guys at a time as hectic as this in my life.
How hard is this to do, just wondering? and how long do you think that it will last? Also, how do I know if the bearing is worn? Please excuse my ignorance, Im learning on limited time and sources! Thanks in advance!</TD></TR></TABLE>
On a level of 1 to 10 its a 7 i think and i think it should last a little while for you save up some money
Old Dec 5, 2005 | 04:54 PM
RedDC5's Avatar
On a level of 1 to 10 its a 7 i think and i think it should last a little while for you save up some money</TD></TR></TABLE>
Man, I am so friggin limited right now! 7, hope I can handle that...
Old Dec 5, 2005 | 06:24 PM
BiG Chris's Avatar
well if you were in the same area as me i would help you out cuz ive done it before and its easy if youve done it before.
Old Dec 7, 2005 | 11:15 AM
RedDC5's Avatar
Dang...everybody's in Cali...Oh well, I appreciate your concern anyways, thanks a lot homie. I think Im just gonna replace the motor with a JDM D15b, I need some more power anyways, its just the whole money issue.
Old Dec 7, 2005 | 12:42 PM
Mr. JDM-GSR's Avatar
im in the atl. lets tear that joint apart!
Old Dec 7, 2005 | 01:40 PM
RedDC5's Avatar
Default Re: (Mr. JDM-GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. JDM-GSR &raquo;</TD></TR><TR><TD CLASS="quote">im in the atl. lets tear that joint apart!</TD></TR></TABLE>
AAaaaa.....how long you gone be here?
Old Dec 7, 2005 | 01:53 PM
just moved to the A. so im guessing 10-15 years
Old Dec 7, 2005 | 02:03 PM
RedDC5's Avatar
A town from the Big apple, Nice..what part of Atlanta u in? Im just bein curious, sorry. Im actually in Florida right now at school, but Ill be up there for Christmas. I dont even think my car can make it up there with this knock, even with some 50 weight in it, this **** is loud.
Old Dec 7, 2005 | 03:26 PM
im in alpharetta right now. if the car can make it up here ican take a look at it for you.
im not a mechanic but i can help you with my limited knowledge .
good friend of mine is a honda tech so i learned from him
Thepowderblue
Jul 28, 2012 12:09 PM
qazaq
Dec 30, 2008 06:57 PM
sipolt89
15
Dec 29, 2008 03:04 PM
serious
Mar 30, 2004 04:17 PM
