Rod knock....
Rod knock....
Disclaimer: Im not a newb, but Im still learning, please bear with me, I REALLY dont need flaming at a time like this.
Okay heres the deal, Im pretty sure I have rod knock, internal knocking sound coming from the bottom of the engine which increases with rpms. Is there anyway to fix this without spending an arm and a leg (maybe a bit, but not too too much) or getting another engine? or can this be diagnosed as another problem? Please help, Im jobless in school and I was already hurting for money before this!!! And once again, I really dont need flaming at a time like this..
the real generic way to get it fixed is to pull the oil pan pop off all the rod caps and put in new bearings that are 1 step bigger than you have then close it all back up. this will get you by for a short while till you can do it right.
i new d15b7 shouldnt be like more than $300 for EVERYTHING. I sold my full d16z6 for $500 and that was still working.
d15s are the bottom of the bucket int he honda world you can get a user coplete engine for cheap
Re: (turbotime)
I had a beater 90 integra that I delivered pizzas with, it began to rod knock, so I pulled the pan and put std size bearings in it. The #3 bearing was worn out, but it didnt spin, and it didnt tear up the crank. I didn't think it would last long, but I put over 10,000 hard miles on it and sold the car, I still see it running around town. The person that bought the car knew about the bearing when he bought it. He beats the **** out of the car everyday. He told me that it smokes so bad, he started running 80w90 gear oil in the motor! But it just wont give up!
Re: (BiG Chris)
Thanx to everyone for their help, I really appreciate you guys at a time as hectic as this in my life.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiG Chris »</TD></TR><TR><TD CLASS="quote">the real generic way to get it fixed is to pull the oil pan pop off all the rod caps and put in new bearings that are 1 step bigger than you have then close it all back up. this will get you by for a short while till you can do it right.</TD></TR></TABLE>
How hard is this to do, just wondering? and how long do you think that it will last? Also, how do I know if the bearing is worn? Please excuse my ignorance, Im learning on limited time and sources! Thanks in advance!
Re: (FerioEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FerioEG »</TD></TR><TR><TD CLASS="quote">Thanx to everyone for their help, I really appreciate you guys at a time as hectic as this in my life.
How hard is this to do, just wondering? and how long do you think that it will last? Also, how do I know if the bearing is worn? Please excuse my ignorance, Im learning on limited time and sources! Thanks in advance!</TD></TR></TABLE>
On a level of 1 to 10 its a 7 i think and i think it should last a little while for you save up some money
Re: (BiG Chris)
On a level of 1 to 10 its a 7 i think and i think it should last a little while for you save up some money</TD></TR></TABLE>
Man, I am so friggin limited right now! 7, hope I can handle that...
Re: (BiG Chris)
Dang...everybody's in Cali...Oh well, I appreciate your concern anyways, thanks a lot homie. I think Im just gonna replace the motor with a JDM D15b, I need some more power anyways, its just the whole money issue.
Re: (Mr. JDM-GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. JDM-GSR »</TD></TR><TR><TD CLASS="quote">im in the atl. lets tear that joint apart!</TD></TR></TABLE>
AAaaaa.....how long you gone be here?
Re: (Mr. JDM-GSR)
A town from the Big apple, Nice..what part of Atlanta u in? Im just bein curious, sorry. Im actually in Florida right now at school, but Ill be up there for Christmas. I dont even think my car can make it up there with this knock, even with some 50 weight in it, this **** is loud.
im in alpharetta right now. if the car can make it up here ican take a look at it for you.
im not a mechanic but i can help you with my limited knowledge .
good friend of mine is a honda tech so i learned from him
