SS Works CRX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsir07 »</TD></TR><TR><TD CLASS="quote">SS-WORKS race EF8 CRX with a 2.0l B18C Spec-R delivering 240ps
</TD></TR></TABLE>Actually, that CRX is not an EF8, It looks to be the zc model (ef 3?) I have the Hyper Rev volume 2. and in it is a page on that car. It has Keihimn FCR 41 carbs on it, it has an 81mm stroke with a 94mm bore to get 2000cc. All fiberglass body panels. Its funny, this car was built about 6 years ago, and it was common for Japanese tuners to sleeve a block at that time. Its a really neat car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 »</TD></TR><TR><TD CLASS="quote">Actually, that CRX is not an EF8, It looks to be the zc model (ef 3?) I have the Hyper Rev volume 2. and in it is a page on that car. It has Keihimn FCR 41 carbs on it, it has an 81mm stroke with a 94mm bore to get 2000cc. All fiberglass body panels. Its funny, this car was built about 6 years ago, and it was common for Japanese tuners to sleeve a block at that time. Its a really neat car.</TD></TR></TABLE>
I think you might have the bore and stroke mixed up, im pretty sure 94mm bore is impossible
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 »</TD></TR><TR><TD CLASS="quote">I meant to say 81mm bore and 94mm stroke--oops!~!</TD></TR></TABLE>
Yeah, I was about to say something...
Only some offset sleeves like Earl (iirc) was testing would even come close to that bore. THat'd be a tight ride though, ~230hp in a tiny rice-grinder. Is that whp, or crank?
In the end, I'd think you'd be better off with a supercharger. I'd be guessing their cams don't have vtec lobes on them (like vtec-killers). If thats the case, SC w/vtec for sure.
Only some offset sleeves like Earl (iirc) was testing would even come close to that bore. THat'd be a tight ride though, ~230hp in a tiny rice-grinder. Is that whp, or crank?In the end, I'd think you'd be better off with a supercharger. I'd be guessing their cams don't have vtec lobes on them (like vtec-killers). If thats the case, SC w/vtec for sure.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/ss-autoworks-crx-3010202/
this has the breakdown of the build, and it's a B16B
